• WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required as is 20 years of participation in forums (not all true). Come here to have fun, be ready to be teased and not take online life too seriously. We now measure and review equipment for free! Click here for details.
The craziest DAC ever #9038AP with distortions analyzer onboard.
EchoChamber
#62
currently, we work with the software for 9038AP. According to the optimistic scenario release date next month, realistic September, pessimistic - this year.
@IVX I’d be interested in trying this design in my different setups... please keep us up to date on your efforts. Are you planning to contain the PCB in a box, or will it be strictly DIY?
IVX
IVX
South of China, SHZ area
Thread Starter #63
I like to offer that as PCBA to keep low cost and less problem to me, as I doing all things by myself excluding iOS/Android code.
PS: The new exciting numbers of 9038AP ;) My AP analyzer guaranty only 117.5db SINAD or -117.5db THD+N.
however, if I overload a little my AP analyzer to use 5VRMS range at 5.8VRMS, the minimum reading THD+N becomes less than -120db. As you can see the curve is quite linear and has no any additional corners, hence, the THD+N reading is still accurate.
I'm sure 9038AP with single DAC config has SINAD range 120..122db. BTW, that's slightly lower than ES9038Q2M datasheet promised.
EchoChamber
#64
Impressive numbers. I’m cool with DIY, I’ve just became a little lazy with time..., but I’ll figure out a small case for it if you’re able to produce the PCB.
DeepSpace57
#68
does it have xlr outputs as lineout?
IVX
IVX
Thread Starter #70
Some update here, 9038AP DUAL DAC tested. As expected, SNR and Dynamic Range improved for 3db(129db(A)), hence, THD+N aka SINAD reading also improved(120db vs 122db).
THD+N vs level sweep with different MCLK, blue - 25MHz, red - 50MHz(remember the ESS hump?).
AES17 Dynamic Range 129.5db(A)
1kHz 0dbfs FFT
IVX
IVX
Thread Starter #74
Oh, I forgot to mention, the first plot THD+N vs Level was performed with an additional high-resolution preamp with an analog notch filter(the noise-limited THD+N level -125db i.e. even AP sys1 can see precisely THD+N 0.000055%). MY AP SYS2522, if I lucky with the voltage range, does correctly see THD+N levels near to -120db but seems at the least bits of its resolution and I can't see .00007% or .00006% but only .00008% and next .00005% next .00000% or like that. With the new preamp, I can surely see down to .00005% range.
