The Cranberries – No Need To Argue – When streaming services decide which version we have to listen to – Review -(CD, vinyl streaming,1985-2025...)
Jean.Francois
Hello,
No Need to Argue is the second studio album by The Cranberries, released in 1994.
Reviewing an album takes a lot of time, and I work in several stages to complete it. In the case of this album, I had already prepared the analysis of the available versions while waiting for the anniversary edition to be released.
However, when the 2025 anniversary edition came out, the previous Deluxe version had disappeared from Tidal (as well as from other streaming platforms).
I decided to keep it in the review, even though it is no longer accessible today, because it clearly highlights the limitations of streaming services: for this album, it is now impossible to choose which version you want to listen to.
This shows that streaming only offers the version(s) it chooses for an album, and that to listen to the original version, it has become necessary to turn to physical formats such as CDs or vinyl records.
Between the original CD and the 2025 Tidal version, there is a slight loss in dynamics, dropping from DR11 to DR9. However, the most noticeable difference lies in the tonal balance, as shown in the spectral comparison below.
sample - The Cranberries -  No Need To Argue -  spectrum - CD (white) vs Tidal  30th 2025 (blu...jpg
The two spectra are similar, but with an accentuation in the bass below 60 Hz up to 8dB for the CD version (green area) and an attenuation in the treble (yellow area) up to 4-5 dB for the CD version. These differences will give a different tonal balance between these two versions. The CD is limited to 22 kHz (yellow arrow) due to its sampling frequency of 44.1 kHz.
When listening, the original CD version has a more solid low-end foundation. This is surprising for a 2025 release, as it is usually the remastered versions that feature stronger bass.
The same difference in sound balance can be heard between the 2020 and 2025 vinyl editions.
The Dolby Atmos mix is mainly front-oriented, with some subtle extensions in the side speakers (in a 7.1.4 setup), while the rear channels are used sparingly, except on tracks like Ridiculous Thoughts and No Need To Argue. The same sonic balance can be found as in the 2025 streaming and vinyl editions, with a less prominent low-end extension, resulting in a clearer and more detailed rendering.
You can access the high-resolution samples to compare the different versions by ear, as well as all the measurements, by clicking HERE (link).
Enjoy listening,
Jean-François
This post is giving me a good ol' case of Schadenfreude.
so... I mean... all y'all that support streaming cast your vote for what you'll get for your subscriptions a long time ago.
