Unfortunately the norm for tonearm-needle compliance has (similar to the whole vinyl revival trend) has taken a as-backwards step in what would be the best technical solutions for the medium.
This has reminded me to open a topic within this thread.
THE COMPLIANCE/MASS MATCHING MYTH?
The standard formula for matching cartridge compliance to tonearm effective mass, which dates from the 1950s, predicts that excessive subsonic resonances will result when a high compliance cartridge is used on a high effective mass tonearm, or a low compliance cartridge is used on a low effective mass tonearm.
And yet, when two cartridges with compliances varying by a factor of two (or three) are put on the same tonearm, the resonant frequency doesn’t vary by a factor of root two (or three) as per the formula. Instead, it often stays pretty much the same or a small variation. And the response to a sweep signal also seems to have a variety of components, not a simple resonance at a particular frequency.
This probably means that modern cartridges (no idea about the vintage gear) have either too much damping to build up much of a resonance, and/or their suspensions have complex stress-strain functions that don’t resonate in the way that a simple spring suspension would.
I believe that this is why Gandy won’t publish compliance values for Rega cartridges: he doesn’t believe it gives a useful guide to the suitability of a given cartridge for use in a given tonearm. (Some claim he does it to trap customers into using Rega carts with Rega arms, but I don't think cynical is right in this case.) And IMHO he seems to be on firm ground.
This doesn’t mean that every cartridge will behave perfectly in every tonearm, but it does mean we should ignore the usual way of deciding the question. If one already has the cartridge and the tonearm, a sweep test with an appropriate LP test track is a good way to decide. But for a shopper who wants answers up front, it isn’t easy….and the usual formula is not the way. I am tempted to suggest sticking to ‘all-purpose’ cartridges and ‘all-purpose’ tonearms, and treat exotic examples of either as an unknowable risk that one should only consider if willing to find out the hard way, after purchase, by trial and error.
@Bob from Florida what do you think? Have you been using the standard formulae to derive tonearm-cart combinations for your own use and for making recommendations?
cheers
