Have you seen how much even used LP12 platters go for. Some enterprising soul is selling stainless steel platters too - if they weigh more than the stock one, I'd suggest that even a Cirkus bearing couldn't take the extra weight without accelerated wear.
Once upon a time, Thorens decided to do their take on the three-spring suspended sub-chassis idea so well realised in the AR deck (my respect and yeah, love, for this model has grown hugely the longer I've been around). They moved the spring positions around (tut tut) and, where they kind-of got away with it in the TD150, the heavily derived RD11/LP12 extra platter mass and later, greater arm physical mass, totally upset the balance and Linn had to do extensive research (we were told) on spring rates under load and so on. Modern LP12s are better aligned and usually fall together well, but not in the 80s. A good running TD150 is an excellent machine to play records on, the multi-material sub-chassis actually works well and it looks (and 'sounds' hehehe) even better in an LP12 plinth, which it fits pretty much exactly.
Anyway, good luck with the Axis. if the arm is a Basik Plus, the counterweight used to be a very firm friction fit as you screwed it in and out. After a few years, the decoupling cylinder can turn to mush and the only cure is to find some silicon tube the right diameter, cut to length, re-fit the insert and off you go. There 'used' to be a sonic benefit in not having the counterweight freely spinning as some of them do today. My own Basik Plus is a halfway house last time I used it. If the arm is an Akito (made of metallic plasticine we felt
), fix the deck and run for the hills... Motors seem to last okay i think and the faults I discovered on ageing ones were main board related. The image below was nicked from this site discussing a repair which may or may not be useful -
andydoz.blogspot.com
