The Courteous Vinyl Playback Discussion
Very interesting, thank you for taking the time.
No problem!
Not knowing what is what, playing those files back to back, I did not hear any difference.
This is why I don’t bother with blind listening tests anymore. The measurements tell me all I need to know.
It's also why I no longer tweak the hardware on my analog side (not trying to discourage anyone from tweaking for fun, experimentation etc). I will keep what I have until it breaks. All my tweaks are done in the digital domain where I can easily back them out if I don’t like the results. The last analog change I am in the midst of doing (which I don’t consider a tweak but a purposeful elimination of an analog component) is moving the RIAA re-construction (or de-construction lol) into the digital domain, removing that analog portion from the chain.
No problem!
I too came to that conclusion. I keep my turntables correctly set up for cartridge alignment, and tracking weight. Bias I deliberately underbias as that helps avoid skips with any damaged LPs, as pretty much all my records are used and 40+ years old. All other tweaks I have long given up on as making next to no difference. Just keep the records and stylus clean.
One thing I've got lined up as an autumn/winter project is a valved RIAA phono amp. I know the measured performance will be a lot worse than my existing IC based phono amps, but I'm interested in how audible the differences will be.
I am not sure to follow. Like in this case, from the measurement you have, would you expect it to be audible?
It is my belief (for what it is worth) that if it measure the same, it sounds the same, but if it does not measure the same without doing a “blind” test, I do not know if it is audible or not, and even if it is somehow audible, will it matter to me or not.
There are some fascinating arms out there.... a short list of arms I find interesting:
Revox Linear Tracking arm (I have this)
JVC QL-Yxx electro damped arms (and equivalents from Denon, Sony)
Dynavector Tonearm ( https://www.dynavector.com/audio/507mk2.php )
Moerch ( https://www.analogplanet.com/content/analog-corner-100 )
Rabco ST7 linear tracking arm (as per the Harman turntable)
Jelco Oil damped arms (a more "standard" arm - very nicely made with oil damping)
I find all of those interesting, along with my:
Technics SL-M3 (linear tracking, Titanium Nitride tone arm)
In the measurements (with a TT), things that maybe occurring below 20 Hz may not be directly audible but may have an effect on audible things higher in the FR range & in the tracking ability (both of which would likely be audible, but you never know until you check with measurements).
If it is not audible, great. But if there is something audible & one has difficulty finding what it is, here is another thing to look into.
And may be sucking up lot's of amplifier power, driving your woofers with in-audible to us sounds.
I combined the two traces onto one graph to make it easier to see. The blue line is system 1, the white line is system 2:
The changes are not very large. Where there are larger deviations it is for brief moments of time, so while I can’t say no one will be able to hear the difference, they are there. For me, these are inconsequential as I EQ all my needle drops.
@Cote Dazur - I took a couple of minutes to EQ that track to what I would listen to.
Here is the what the dynamics trace looks like for the EQed version:
I placed a level matched copy into the same folder for you to compare, this time you will notice a big difference in sound. This is what I would be listening to - created from a vinyl rip. Hopefully this helps clarify why I no longer chase vinyl hardware gains.
I replaced caps of my Axis mk2 1-2 years ago. Powered on since 1990 all old caps except one measured within spec. However if the motor fails there is no replacement other than taking it from another Axis. LP12/Premotec motors differ. Take care when desoldering. The PCB traces sometimes lift and I had to do some repair.
Axis can be upgraded with the LP12 platter for better stability. Just needs readjusting the rubber suspension so that the platter runs above the plinth frame.
Have you seen how much even used LP12 platters go for. Some enterprising soul is selling stainless steel platters too - if they weigh more than the stock one, I'd suggest that even a Cirkus bearing couldn't take the extra weight without accelerated wear.
Once upon a time, Thorens decided to do their take on the three-spring suspended sub-chassis idea so well realised in the AR deck (my respect and yeah, love, for this model has grown hugely the longer I've been around). They moved the spring positions around (tut tut) and, where they kind-of got away with it in the TD150, the heavily derived RD11/LP12 extra platter mass and later, greater arm physical mass, totally upset the balance and Linn had to do extensive research (we were told) on spring rates under load and so on. Modern LP12s are better aligned and usually fall together well, but not in the 80s. A good running TD150 is an excellent machine to play records on, the multi-material sub-chassis actually works well and it looks (and 'sounds' hehehe) even better in an LP12 plinth, which it fits pretty much exactly.
Anyway, good luck with the Axis. if the arm is a Basik Plus, the counterweight used to be a very firm friction fit as you screwed it in and out. After a few years, the decoupling cylinder can turn to mush and the only cure is to find some silicon tube the right diameter, cut to length, re-fit the insert and off you go. There 'used' to be a sonic benefit in not having the counterweight freely spinning as some of them do today. My own Basik Plus is a halfway house last time I used it. If the arm is an Akito (made of metallic plasticine we felt :D), fix the deck and run for the hills... Motors seem to last okay i think and the faults I discovered on ageing ones were main board related. The image below was nicked from this site discussing a repair which may or may not be useful -
I have done the Kipple Distortion Test a few times and have tested my sensitivity to FR changes with both music and with sine tones in order to get a sense of how sensitive I am to these types of changes. Once you calibrate your sensitivity (which should be done every once in a while as our hearing changes), you can get a really good sense from traces if you would be able to hear the differences.
I know Linn stuff is expensive, just replacing the belt... The platter is... well quite expensive at €250-300 , but at least it add mass and you actually get better performance. After >30 years of use, I was just ready for something else but not wiling to buy a new Technics at €3000. Bearing wear is really not a concern IMO. The >30 year old bearing was shiny as a mirror and I just use the black oil and forget it.
Before the Axis I had a TD166 that served me well. I have the Axis mk2 model, so it came with Akito arm and not the self-start problem of the motor PSU. The Akito is in the drawer and needs service; sticky bearings. I replaced it with a used Moerch UP-4 a few years ago, and now it has a Moerch DP-8, bought "new" for less than half price. Works as a charm. I've been using the Shure V15Vx + JICO SAS/B for many years, but recently I saw a used V15V HE and bought it. Couldn't be happier.
Yup, you just need to know what to listen for.
It was not difficult though.
Agreed, but the difference between the 2 needle drops is small compared to the EQ’d needle drop - so if you are looking for gains, EQ (and other plugins (which are sometimes just disguised EQ)) is the way to go imo.
Hm, I compared the 1 and 2, and my rip as well. Isn't it quite different in the bass? I however heard the clear difference in the highs though. Maybe I am doing it wrong. Edit there is a clear audible difference in the bass between all three. No ABX needed.
Audio Origami's Johnnie can 'do' Akitos I believe, but Linn were stung with too-soft materials being used. I never liked it even in later form as it always sounds as grainy as it feels to the touch (mixed senses, but I heard the 'grain' of a late one without going anywhere near it) and it had gone from a two hundred quid-ish arm to a supposedly better material in construction £1600+ by its end . If your bearing's good then that's wonderful, but seriously, I've seen perfect LP12 bearings from the late 70s, mid 80s ones where the contact point almost 'burns' in the first hour of use - Linn replaced most but some are still out there from new - and in between ones which were salvaged with the black oil (engine oil and molyslip - I saw it being made up but no idea of the proportion), but which have gone off now after forty years. I think the Cirkus 'upgrade' (well, it was, sonically) may have caught most as many owners wanted to improve the sound and what better than an 'upgrade' to help bolster the coffers in the early 90s after ditching over half their UK dealers over the contract situation they put forward...
All this Linn talk. So many other wonderful 'sounding' record players out there. We only saw them fleetingly in the UK, but the Pioneer PL-71 is an excellent if not the nicest looking tool to play records on (adjustment pots can go noisy I gather and a visual favourite of mine, the Yamaha YP800, which I'd love to 'hear' today.
And then we have Lencos, late ones so misunderstood as the arms get ripped off, the running gear ripped off and placed on flat plates minus the idler retractor when switched off, so the wheel develops flats when not running (oh...yes...they...do!), but the owners don't seem to bother let alone care about this...
Here's one of mine :oops:
Yes, there are many older fine decks around from Denon, Pioneer, Yamaha and Sansui as well. If the Axis fails, I might go for one of those or a Technics. With respect to repairing the Akito; I might do it just as a hobby project. Not too difficult I think.
(...) Later decks had it adjustable I recall.
Well, the 704 and 721 still sported a 2x-Antiresonator, whereas the adjustable Tuning-Antiresonator was introduced with the ULM arms on the 714Q and 731Q.
I've never been a fan of those proprietary ULM mounts, though (especially not the even lighter 2nd gen. with those fragile plastic hooks and the for my taste ugly looking halfinch-mount adaptor plate design...). The 714Q and 731Q were somewhat special, however, as these would sport a three part headshell/carrier design (and the halfinch-mount adaptor kit already included in the original accessories) with two different front parts for the headshell, of which the short one was for the new TK26 and TK27 carriers (the TK26 for the 1st gen. ULM carts made for Dual by Ortofon and the TK27 for the MCC110 MC cart made for Dual by AT) and the long one for use with the usual, already established TK24 carriers (of which a silver-coloured exemplar was part of the aforementioned halfinch-mount adaptor kit).
Greetings from Munich!
Manfred / lini
Are you using the 1min samples to generate this? If so, both of mine are at the same Intergrated loudness:
System 1:
Which should generate this spectrum:
System 2:
Spectrum:
There is approximately a 3 dB difference between the two systems at the shown peak. Incidentally, this is one of the reasons why I am moving the RIAA to digital.
You will need to adjust your rip to the same time parameters (1:10 long, 10 seconds fade out) and integrated loudness = -15.2. I did it and placed a copy in the folder.
Your rip being a different pressing, I would expect differences - like the correction in yours for the two bumps on the high end in my pressing.
System 1:
System 2:
Spectrum:
I started listening to the highs since that is usually where cartridges differ (your 1 and 2 tracks in the folder). But going back between 1 and 2, there is a large difference in bass between track 1 and 2, which came out the same in my measurements. There is really no contest here. Clear difference. I suspect you did not mix up the EQ-track with the 1 and 2?
I see the confusion now. I was talking about system 1 and 2, not referring to track numbers but the titles of the files. I numbered them so that there is no confusion. You were listening to the EQ’d track. :)
Track 1 = System 1
Track 2 = System 2
Track 3 = Thomas’ Rip
Track 4 = System 1 with EQ.
