Good point as regards the oils. I have a collection of Duals and Garrards (sorry
@Sal1950) and a sinter-safe 'sticky' oil such as the vactra is important here. It was suggested to me that a sloiughtly viscous oil may be better for the single point bearings as Thorens use, but I daren't say that with certainty.
The AXIS, contrary to Colloms' comments in the 'Choice review, is NOT an LP12 on the cheap. It certainly lacks the 80s era LP12s bass bloom, but it's all a bit 2-D as supplied and used with K9 and the rubber-diaphragm suspension could be upset with an oscillating kind of feedback into amps with full bandwidth below 20Hz, the stylus wobbling alarmingly in a vertical motion. Mind you, the Basik Plus arm is a bit 'lively' in resonance terms (maybe tamed with a VMX740 or better and the 'sound' was also judged better with a Linn T-cable we fitted at the request of a client (don't you lot DARE to say cables make no difference in this instance!). A well cared for and serviced Lenco GL75 (yes, even with that massive tonearm) was a much nicer thing to listen to LPs via and they used to be very cheap - no need to carve them up and ditch the arm either these days, but the sheeple don't listen
Main thing with the Axis (and early LP12 Valhalla supplies) is that we were told to leave them powered 24/7 and most of the electrolytics on these boards cooked over twenty or so years, making subsequent repairs rather difficult! I have fitted the third party 'Hercules' two speed Valhalla replacement board to an Axis, leaving the old board in place unpowered as instructed and tapping into the motor wiring, but it's a right bodge as the excess torque must add noise (Linn ceased service on the Axis in 2001 or so).
