The Courteous Vinyl Playback Discussion
Thanks, wanted a direct comparison.
I'm 71. My hearing rolls off a little after 13k. I have no tinnitus.
The monitor chain is an Acer Aspire 5 laptop>Topping E30 DAC>Topping L30 headphone amp>Crinicle Zero 2 @ IEM(s).
First, the all-digital chain. I'm using Tidal: this transfer is Redbook. Then I heard your transfer of the LP.
It is a full step upwards in pitch—say, C to D—compared to the digital source.
Time to get your turntable's speed checked, buddah.
Just sayin"
I will check it when home again. Last time it was fine though. 3150 Hz Tacet record gave 3150.138 Hz.
Now I’m a little confused, I thought it was the other way around, that a higher number of anti-skating is needed if the force is strong towards the middle of the record. Isn't that how it works?
I have another question that I have read contradictory information about, where some people have said one thing and others have said the opposite. Is the inside groove (towards the middle of the record) the left or the right channel? :)
If you go to the Soundsmith link I posted a few replies prior to this, Peter does a decent job explaining things.
I used to use a test record with the 4 tracks of increasing modulation and make heroic efforts to get the 4th track compensated. This would result in too much anti-skate pulling the stylus out as it cued to track one. When I went to "just enough" anti-skate to keep the stylus barely ahead of the spiral into locked runout groove, everything seemed more "balanced". Neutral cueing at beginning and nothing "radical" in or out across the record. Plus, this can be done without any test gear!
I use the Frank Schroder/Soundsmith method. With the stylus at the end of the album side, adjust anti-skate until the stylus stays just ahead of the spiral in groove before getting locked into the runout groove.
From the above link, the critical paragraph.
“For a given VTF (any amount of VTF) – set the A-S so that the arm VERY SLOWLY drifts inwards when placed on the SURFACE (NOT IN A GROOVE) at the end of a record. You will have a moment to do this until the stylus “pops” into the run-out groove.”
Thanks I will try this out.
I think you’re right that might be the way it is. I get a little confused with anti skating lol
Anti-skating is a very rough and ready affair, as the actual amount needed varies second to second with the modulation level, and more slowly, with the distance from the centre of the record. It also varies with the stylus profile, but at least that's fixed for any one cartridge.
As I've mentioned before, I prefer to under bias rather than overbias, and the Soundsmith method mentioned above will slightly underbias. In effect, it's the blank-disc method using the short section at the end of an LP as a blank disc. I use a blank lacquer as a blank disc when setting bias, and although lacquer isn't the same as vinyl, setting bias is very approximate, and a blank lacquer is cheap and easy to obtain.
S.
S.
You can also simply use a 315 Hz or 1 kHz tone—lightly modulated, or at least reasonably so (like the 1 kHz +12 dB test on the Audioanalog LP, if I recall correctly).
and consider the applied force that is "lowest where seems correct" with value..
I just tried this method and had to reduce the anti-skating from 2.8 to 2.6 on my previous setting for the Technics 1200GR2. This is with the AT33PTG/II cartridge, which has a tracking force of 2.0 grams. The turntable is leveled using a spirit level.
One thing that I never see with my setup, no matter how high I set the anti-skating, is any tendency for the stylus to pull outwards before track one. The pull inwards seems to be much stronger before track one than it is when landing the stylus between the runout grooves.
Stylus pulling outward at track 1 is because of too much anti-skate.
If you have one of those cheap scales you can measure the antiskate force. Balance the arm with stylus guard, set the antiskate to eg 2.0 and turn the scale on its side. Let the arm lift bump into the scale and read the value.
If you mean that the arm is pulled inwards while the stylus pulled outwards it means that you see the skating force. Antiskate pulls the arm outwards so if it is too much antiskate the stylus will tilt left/inwards.
Yes, I understood what you said, but that will never happen in my setup even if I set the anti-skate to the maximum value. The inward force seems to be much stronger close to the record's outer edge (before track 1) than it seems to be in the outrun position.
I see your point. Arm pulling out for too much anti skate.
Try measure your AS force at outer and inner groove positions.
Doesn't look like it... But I don't know what you should check on your end...
ps C to D..more than 10%.( and impacts the execution speed to the same extent.):p
(ps bis
There’s no doubt Thomas-A’s turntable has been checked for speed countless times... and if there are any deviations, they’ll be nowhere near the 10% mark. ;-) )
As you say 10% difference is a strange finding.
I will try that sometime, but to do that, I first need to buy new batteries for the little scale as it’s display indicates they are ”old”, and I have to get a reading pretty fast before that message comes up. :)
i did that in my 1200 ... but forgot to do it at 0 VTF :-) , you're right, in that way you measure only the horizontal force
That's pretty shocking as the point of the vernier tower is stability while you tweak the VTA while playing the record!
Yeah, there is no "key" to stop the inner part of the tower rotating a bit once you undo the locking screw. It is then subject to the tolerances of the screw thread and the socket thread in the inner part, and the washer around the screw and the slot in the outer part. I've tried various added o-rings and washers to some effect.
It's not just me, the Positive Feedback review said similar.
"Worth noting: much has been made of the Stealth's VTA adjustment tower, with many users describing it as offering "on the fly" adjustment. In reality? Not so much. You won't want to use it while a record is playing, and I don't think Music Hall ever intended it as such. It's a little loose when unlocked, so at a minimum, you'll want to lift the tonearm before making adjustments lest you send the stylus skidding across your record."
(ps bis
You play music daily?
Just askin'.
