If you only aim to
reduce the vibrating sound, you go with those Mag Lev feet that
@Bob from Florida is using, which I think are quite expensive. But if you want to
eliminate the vibrating sound to nothing, you should look at the inexpensive Sylomer feet that
@Thomas_A is linking to.
These Sylomer feet has been used here in Sweden for over 30 years, and have been tested extensively at another objective-based forum called Faktiskt, which has been around many years before ASR came to life. Just wanted to mention that, so that no one thinks it’s just me who came to this conclusion. I think Thomas_A has done some deeper tests as well.
The only downside of the soft Sylomer feet is that, in combination with a Technics turntable, you can't put them directly under the existing feet, as those are "jointed," leading to bad balance for the turntable. So, you will need something like a board to place between the original feet and the soft Sylomer feet. My solution was to use a cheap IKEA butcher cutting board, which I showed earlier in this thread. You can’t see the soft feet under the board, making the board look like it’s floating above the surface underneath.
