jarchi
- Joined
- Jun 29, 2020
- Messages
- 6
- Likes
- 0
If you look at big and expensive amp and dac reviews on the Internet, there is a story that people commonly tell.
It's a wider sound stage and feels airy? the reverberation increases and creates a sense of depth'.
Let me give you an example.
"... ... When you switch from the normal OOOO to the OO, the first thing you notice is the extension which is improving. While there also is a wider sound stage, I’m mostly talking about more space and air between the notes, and that from top to bottom, but mostly in the mids area. As a result the original Euforia sounds more intimate compared to the AE, but it in fact it s not intimate per say, it just gives that impression as the AE is even better. ... ..."
This article describes when Headfonia, a fairly popular headphone and peripheral review site, switched from an expensive amplifier to its higher version.
I've seen so many of these expressions of stage size changes. But I've never seen a single person say what principle, or what measurement, can represent this. In other words, is there still a technical limitation today that can objectively measure the sound of headphone amplifiers, and there is an area that must only be judged by the ears?
However, the manufacturer's position on the amplifier should be different. Because you can't produce something you don't know what you're going to do and how you're going to make it If you need to tune the size of the stage when you create an amplifier, you need to create your own parts or circuits that affect it. And if a component changes, you should be able to quantify it. If this is a manufacturing know-how and we can't let the consumer know?, ok we can't say nothing.
For your information, the reviewer below lists the differences between the two amplifiers. Of course it's the same as the manufacturer said.
The new OOOO Edition basically is an upgraded version of the original. New this time:
So the reviewer is saying that changing the internal wiring, capacitors, transformers, and Constant-current source modules can help to expand the staging and improve the sound quality. But we don't know how it affects sound without studying audio deeply. Actually, I'm really curious about this.
And I think this. Today, there are many sites where you can objectively review devices through measuring instruments like here, and Semi-professionals are also in an atmosphere of exchanging opinions with people about technology, so many manufacturers expose specifications when they launch products. Even in this situation, it is not thought that there will be unknown or hidden areas behind the measurement.
I've lived in headphile's life a lot and ... yeh it means I've heard a lot of things too, but I don't think I've ever felt that the stage has expanded dramatically. However, it may not be all that I have experienced. Interestingly, this staging story comes at a very high price product. So I'm also thinking about this. Maybe this is a kind of fantasy marketing using the rarity of the experience of these products.
So I think of it today too. If staging width is actually adjustable, and if some amplifiers actually produce wider and more spacious imaging, what are the specs that can be objectively identified? And will the parts above really affect the staging change? If so, what is the principle?
- Neotech UP-OCC Single crystal signal wiring – extremely pure monocrystalic copper wire, teflon coated – able to transmit signal faster, and with less distortion than OFC or silver wires, comparing to pure silver wires (as used in “regular” Euforia) it makes the top-end of the spectrum sound richer yet less fatiguing
- Higher grade internals including ClarityCap capacitors with CopperConnect technology- for extra smoothness and clarity
- New low-noise-design power transformer – provides even better electromagnetic interference isolation
- Redesigned Constant-current source modules to give rock-solid operating conditions, regardless of the external factors
- Special finish – high gloss space grey applied using highest quality automotive painting process
