ZolaIII
- Joined
- Jul 28, 2019
- Messages
- 4,161
- Likes
- 2,449
Trough is that you don't need an amplifier that has higher THD+N on the level that analog transcender (speaker) can achieve with small enough THD when feed with power it needs to do it. And in the end you won't even push it play even that loud.
That's why folks around hire usually say buy better speakers or hedaphones not a 21 bit SINAD DAC or amp.
If it's a good, cheap quality product which will be enough for the best of those even better and I know even sub 500$ one's (power amplifiers as new) that will get you there.
In the end spend your money where you can hear it and if you are sure that you can at least I see it like that, best regards.
