Hello! Welcome to Audio Science Review. This site is intended as a place to discuss audio under the umbrella of scientific rigour through measurement of equipment. As an introduction for new users, we have created this outline to help you understand the philosophy at the heart of the ASR community. If it does not align with your views, that is entirely fair; you are free to challenge it. Just know that the principles outlined here are precisely what set ASR apart from many other audio websites. Arguments against judging audio equipment by measurement have been advanced for a century, and more than ever in the last few decades. In general, users come here because they have grown weary of this debate.
The basic philosophy of ASR is as follows:
- High quality consumer audio equipment must have high fidelity. Once a recording is published, the transmission medium (radio waves, record grooves, digital files) and devices it passes through (DACs, amplifiers, cables, speakers) should change it as little as possible so that you can hear what the artist intended. If a device does not change the sound passing through it (except the change it is supposed to make, such as amplification), the device is called audibly transparent.
- Because audio passes through several devices before getting to your ears, inaudible effects can compound into something audible. For this reason, it is best to have equipment that is better than audibly transparent.
- The only way to determine if audio equipment is audibly transparent is to take measurements. You must do this using equipment with better characteristics than the equipment you are trying to measure. With modern devices of passable quality, the human auditory system rarely qualifies.
- Because people change across listening sessions, and even moment to moment, they are unreliable in identifying subtle differences in audio equipment.
- If you know what equipment is being used in a listening test, your brain will fill in what you expect to hear. If you don’t know what is being used, your brain will just guess. If somebody tells you that an expensive device sounds better than a cheap one, the person probably really did hear an improvement in quality. Put both devices behind a curtain however, and the story might be very different. Because of this, repeated double-blinded tests are the only human experiments that matter (unless the difference reported is truly obvious, such as blatant distortion).
The above does not take into account personal taste. You buy audio equipment so you can enjoy music, movies, etcetera; not to get pretty graphs on an audio analyzer. In your personal audio chain, some
coloration of sound might be desirable. For example, you might prefer to boost the bass, or the mids. You might even enjoy introducing distortion that the artists did not intend. If you want a sound system that is not audibly transparent, it is far better to color your audio using EQ or effects that
you control than to buy components with coloration permanently baked into their design. Then you can adjust or defeat the coloration based on the needs of a specific recording, or changes in your tastes.
Thank you for taking the time to read this document. We hope that it has been edifying.
