@TimVG I don't understand why you're addressing me. I agree with everything, except that I can question preferences as such—preferences, that is. I've had my own experiences with various setups, and I'm convinced of what I write.
THD as a “surrogate marker”
The article compares audio metrics like THD to surrogate markers in medicine. THD is useful, measurable, and worth optimizing, but it is not the final endpoint. The final endpoint in audio is the listening experience. PURIFI’s warning is that the industry may be “treating the numbers” instead of the actual perceptual result. (PURIFI)
What exactly is empirical about theorizing about something whose very existence has not been established? Where's the empiricism involved in that process? Genuine questions, because all I see is a priori reasoning.
Yes, and preferably, spaced away from the wall a few inches.Something I recall reading in Toole’s book was that if your speakers have good on and off axis response, people prefer the sound when not treating first reflection points. If you’re speakers have problems with their off axis response, treating the first reflection points could possibly improve the overall sound by absorbing some of those issues.
Also, if you are going to treat the first reflection points you have to do it properly to avoid messing up a speaker with good off axis response. For example, I believe any absorbers need to at least 4 inches thick.
My understanding is that a "really good seat" in a concert hall is within the LLD distance from the stage AND has sufficient temporal separation between the direct and reverberant sound to enable the perception of envelopment. These tend to be the seats up close and near the center.
Maybe this is just me, but being able to close my eyes and effortlessly visualize where the sound images are located functions sort of like a surrogate for being able to see the performers. I have no idea whether imaging plays a similar role for anyone else.
It *is* bad science because it relies on lay intuition that reflections are echoes and hence, they must be eliminated. This invariably leads to rooms that are super dead.... There is no defensible position to say that sidewall reflections should be absorbed by default.
Agreed! THAT approach (absorption) to minimizing early same-side-wall reflections IS (imo) bad science.
And THAT has never been what I have advocated (nor Earl). From a post earlier today:
Why? Being an audiophile is like being fooled by the presentation being more than it is. If side reflections make your brain enjoy the experience more, then doing otherwise is the anthesis of being an audiophile.
What is the frequency response of the phantom center? You know, where the signer would be or your single violin.
A bit.But it sounds like you are saying that choosing a package of attributes which does not include apparent-source-width enhancing sidewall reflections would be "the antithesis" of what we should be doing. Am I misunderstanding you?
Not at all. I meant the opposite. The pursuit of what gear and setup to enjoy music to the max is what being an audiophile is about. To then change a setup as to make it "pure" and with it, reduce that enjoyment would be the antithesis of being an audiophile.Or, are you including the assumption that "being an audiophile" is a bad thing?
My setup is the same. I explained earlier that this is a subtle effect. If your home situation doesn't allow it, then that is that. What you don't want to do is go slap absorbers everywhere there is a reflection as some people do. Get superbly designed speakers, apply EQ for bass, and enjoy the music. Don't listen to people who go by lay intuition or folklore rooted in Pro space that reflections are bad and you have to get rid of all of them. The whole purpose of a speaker with good off axis response is to reduce such anxiety.Do you recall the photo of @Floyd Toole's room from his home in California, the one where his Revel Salon 2's are standing on their heads atop a piece of furniture? On the left-hand side he has thick curtains where the first same-side-wall reflection would have happened, and on the right side he has an open doorway where the first same-side-wall reflection would have happened. So the ASW-broadening sidewall reflections are greatly diminished or eliminated. I hope that's not the antithesis of something desirable.
I use it as a predictor for the rest of the measurements in electronics at the two ends of the spectrum. A very high SINAD shows extreme care in design and will almost always result in the rest of the measurements being superb as well. Conversely, a poor SINAD almost guarantees the rest of the measurements will be poor as well.I hope I haven't misunderstood, but it's my impression that Amir himself has touted THD (or SINAD) as a "surrogate marker".
A bit.I am saying if sidewall reflections make a listener believe more in what they are hearing, you don't want to eliminate them for the sake of it. The reflections are making up for the shortfalls of the system+recording to the mind.
I explained earlier that this is a subtle effect. If your home situation doesn't allow it, then that is that. What you don't want to do is go slap absorbers everywhere there is a reflection as some people do. Get superbly designed speakers, apply EQ for bass, and enjoy the music. Don't listen to people who go by lay intuition or folklore rooted in Pro space that reflects are bad and you have to get rid of all of them. The whole purpose of a speaker with good off axis response is to reduce such anxiety.
Given the very big impact that the room has on SQ, however, it is also possible to work “on the room”. It should be no dogma to use the room “as is“ and that includes to implement reflection, diffusion and absorption to some (reasonable) degree. It can make quite a difference (Toole has a full chapter on this).I take a somewhat different approach to "making up for the shortfalls of the system+recording", but I think we're both advocating speakers + setup that works "with the room" rather than "against the room" to make up for some of the shortfalls inherent to two-channel playback.
I am all in favor of enhancing the experience! Imo the goal is to approximate the experience of hearing a live performance, moreso than to replicate "what the recording engineer heard".
Or, are you including the assumption that "being an audiophile" is a bad thing? That word is used as a pejorative around here so pardon my confusion.
Do you recall the photo of @Floyd Toole's room from his home in California, the one where his Revel Salon 2's are standing on their heads atop a piece of furniture? On the left-hand side he has thick curtains where the first same-side-wall reflection would have happened, and on the right side he has an open doorway where the first same-side-wall reflection would have happened. So the ASW-broadening sidewall reflections were greatly diminished or eliminated. I hope that's not the antithesis of something desirable.
Note also that Floyd Toole used "tasteful upmixing" for stereo listening, and the contribution of the surround speakers was not part of "what the recording engineer heard", so I speculate that his goal was also something along the lines of enhancing the playback experience rather than replicating the recording engineer's experience.
If "audibility" matters more than what the frequency response measurement looks like, you might find this interesting.
Francis Rumsey cites a study which shows a correlation between the quality of a phantom image and the perceived tonal quality. In particular, the perception of coloration from stereo's 2 kHz comb filter dip goes away when you have a good enough phantom center image! And in general as the ability to detect a spatial image improves, the ability to detect a timbral coloration decreases. He calls this phenomenon "decoloration".
Here is his lecture, cued up to that part:
In this kind of discussion, advocating for a particular approach can come across as saying or implying that everything else is wrong. That's not what I intend; I'm trying to say that a particular approach has legitimacy, rather than that it's the one and only correct way.
It turned out that good timbral quality was significantly more important than any other factors such as spaciousness or front stage imaging (and also interesting that naïve listeners apparently did not rate imaging much at all, versus experience listeners who cared about it).
... a majority of surround systems I would experience at stores and at home theater set ups struck me as timbrally bland, even if immersive. The sound “ surrounded” but it did not reward fine attention to timbral qualities of the sound. [emphasis Duke's]
Yes! That part starts around 25:00 in the video.
Yes, he goes into that somewhat. In investigating wavefield synthesis, wherein many channels and many speakers in an array seek to replicate the wavefield, it was found that the more channels used, the more coloration resulted! This part starts around 51:10; this is not the exact same situation as multichannel audio, but it's an interesting finding anyway, imo, and suggests that a multiplicity of channels may not be the ideal solution after all, as least not in the configurations tested.
My take-away is that, in practice, there may be some fine-tuning involved to get a really good balance of desirable attributes without having distracting colorations.
I ended up choosing my side and back surround speakers simply by ear. I searched for speakers that in my perception sounded timbrally like the Hales. That worked out to be speakers from the Monitor Audio Bronze line. Not the more expensive platinum series that I could’ve bought instead - they struck me as sounding a bit too tipped up and bleached sounding. But the cheaper Bronze line had a slightly darker warmer tone, and those ended up matching with the Hales beautifully. And then I’m careful not to play the surrounds too loud for I think some of the reasons you are getting it.
