Teufel Studio 5X – New 3-Way Active Monitor, Klippel NFS Developed
Audionaut
NRW Germany
Teufel has just introduced the new Studio 5X, an active 3-way nearfield monitor with a coaxial mid/tweeter and a separate 5.25" woofer.
What caught my attention is that Teufel says the speaker was developed using the Klippel Near-Field Scanner, with particular emphasis on a linear frequency response and controlled directivity. It also uses DSP with phase-linear filters and three Class-D amplifier channels per speaker. Teufel specifies 42 Hz–20 kHz at -3 dB and 106 dB maximum SPL.
At €499 per pair, they are also relatively affordable for an active 3-way design.
I’m quite curious to see how they actually measure. Considering the Klippel-based development, these could be interesting candidates for a proper NFS test.
Competes with Kali IN-5.
Visible off to the side is the horizontal map:View attachment 561698
I had posted about this new release in the master list thread earlier today and commented that I have my doubts that despite it's NFS optimisation it will have an optimal spinorama due to the horn over its coax and this image seems to kind of confirm it, still would be happy to be proven wrong so looking forward to seeing detailed measurements.
Eh, as long as it's flat enough, it looks like the intended application is nearfield only.
Odd little coax there but I'll wait for the final spins to judge. However, given that the (apparently) same spin shows up twice in the background, I'm not super optimistic. Looks like a relatively rough horizontal with a significant pinch before the Low/Mid crossover. For 500 moneys you can do better, but there may be other reasons to buy it, we'll see. I have a relatively good impression of Teufel from back in the 2010s when they had some of the better bluetooth speakers out there.
