Hi,
As I explained on my
More than we hear post here, there are multiple elements of difference that we can test.
The RME test is a good one the verify the digital output is not modified, but it requires RME hardware. My tests are more universal and also about tracking capabilities of the laser head together with Servo control.
Tracking capabilities are tested as described below:
Test type | Technical test |
Variation of linear cutting velocity | From 1.20m/s to 1.40m/s |
Variation of track pitch | From 1.5µm to 1.7µm |
Combined variations of track pitch and velocity | From 1.20m/s & 1.5µm to 1.40m/s & 1.7µm |
HF detection (asymmetry pitch/flat ratio) | Variation from 2% to 18% |
Drop-outs resistance | From 0.05mm (0.038ms) to 4mm (3.080ms) |
Combined drop-outs and smallest pitch | From 1.5µm & 1mm to 1.5µm & 2.4mm |
Successive drop-outs | From 2x0.1mm to 2x3mm |
Physical tracking tests capabilities of a CD player.
I also introduced a new test with the review of the TASCAM CD-200, that is about to verify the data are not modified. It is simply reusing the intersample overs test at 5512.50Hz, with a phase shift of 67.5°. This signal generates an overshoot of +0.69dB and so if the signal would be modified before being sent, it would show either a reduction of amplitude or we'd see some sort of saturation and added distortion/noise. Of course this test is done in digital domain which means I'm capturing the digital output of the CD Player via either coax or optical SPDIF outputs.
In this test I compare the WAV File (directly processed by the PC), with the digital output of the CD-Player:
5512.50Hz @0dBFS with 67.5° phase shift, comparison between original WAV file and from the digital output of the CD Player
The two traces (and measurements) are identical, including the +0.69dBFS that the measurement software (REW) sees from the phase shift. This means that the digital data sent by the TASCAM is the same as what it was from the WAV File.
I still complement this test with few others, but it's sufficient alone to confirm "digital perfect" output.
Note that one thing people don't talk about is the precision of the clock. Some CD Players use a separate clock for the output, but all might suffer from a lack of precision that will transition to the DAC, as the PLL will not suppress that (only filter the variation, say the carrier of that imprecision). So I run a "pitch control" test that is based on a 19'997Hz sine and I calculate the deviation from that frequency, and show it in ppm. A result of 70-50ppm is good enough for audio. Modern CD players should have no issue to reach 1ppm, which is the limit of what I can calculate (and that would be 19'9997.01Hz measured instead of 19'997.00Hz).
I can share my
Test CD with you, if you want.
