Interesting! Very cool test.
This is not central to your point, but I was wondering about this sentence: "If I attempted to match the frequency response between the two drivers I would end up with new variables such as increased group delay on the driver receiving additional EQ". This is probably a complete noob question on my part, but can you explain this? Why does eq increase group delay? Does this always happen when equalizing a driver?
Good points.
I will share a method that has proven to work and gives reproducible results:
- both drivers
must be EQ'd to the excact same frequency response on a test baffle (of both magnitude and phase/group-delay), and levels matched. That response should be close to a realistic response one would choose in the acual application, so clearly band-limited and clean. Best done with FIR, from one of the DRC/XO packages like AudioVero's Acourate. As drivers are minumum phase and the target is (selected as) mimimum phase, the correction will also be minimum phase. When the drivers are of the same cone area, the cone movement will now be identical, and thus same operating conditions for each driver, at least to first order (neglecting the distortion)
- then record each speaker's response to piece of music playback, test signal, whatever. No change in driver or microphone position allowed .. this also applies for the initial measurements. Close miking (< 1m) and large damped room if feasible.
- listen to the recordings with headphones in a A/B-test (or ABX)
The obtained data (the measured impulse responses) can also be directly be used to "extract" the distortion and other ill effects in subtractive analysis:
- convolve the source signal offline with the filtered IR, that obtains the linear part of the response to the signals in a test file
- compare that to the original recording (subtraction, using DeltaWave), which will isolate or at least magnify the distortion when listening to the residual.
