TEST FILES. How to verify the quality of your audio system and other audio tests.
Soniclife
None of the files were clipping (stayed well below clipping levels) but they all differ in amplitude, peak levels and harmonic contents.
I had assumed they were not level matched, you can always tell when it's not explicitly stated how they were matched. Thanks for checking.
solderdude
The Neitherlands
I guess in real life you are not able to differentiate between two red fruits such as strawberry and watermelon :)
What's it have to do with the discussed files and what they really represent ?
solderdude
The Neitherlands
The strange part here is that the guy who made the files (not Maty) mentioned all the files were 'normalized'.
I looked at the original article from the guy who made this comparison (= not a test).
Of course one can 'hit' the normalize button and assume this makes all files have the same peak level and subsequentially assume also the same average levels, but when the peak levels and average levels are not the same the average levels will differ.
This easily happens when using a microphone and speakers in a room so the 'normalizing' does not seem to have had the desired effect.
Wombat
Australia
solderdude
The Neitherlands
I know the SF10 plots do not show the exact peaks zoomed out over an entire song BUT when differences look this big the differences are really substantial.
Below all the plots of the different files in an animated GIF in a row. Big enough to be audible ? Caused by differences in amps ? You can even see the 180 degrees phase shift with some files.
Sgt. Ear Ache
Winnipeg Canada
So what you are wanting us to do is to prove we can hear the difference (or at least say we can or can't) between these objectively different files? Then, if we say we can't, it will validate your claims that you can hear all sorts of "golden ear" differences that don't show up in objective measurements. I see. Here's the problem... if we could compare two files as Solderdude has above and see those sorts of differences between them in measurable terms, none of us would claim it isn't possible to hear those differences. But when you compare for example an mp3 at 320kps and an flac file you don't see those sorts of differences (assuming good level matching of course.) So when people claim they can hear a difference between two files that measure nearly identically (unlike the files you are asking us to listen to) but they haven't done any actual blind testing of those claims, that's when we call BS on it. In other words, nobody has an issue with folks claiming they can taste the difference between a strawberry and a watermelon. We have a problem with people claiming they can taste the difference between a strawberry and a slightly smaller strawberry.
SIY
Alfred, NY
Why would anyone waste time with a badly implemented "experiment"? Set files up correctly and maybe someone will try it. What you have there would be tossed out of a 6th grade science fair.
Blumlein 88
Why indeed. It made me think someone wasn't careful when they were MP3. I didn't check, but I'm not surprised they aren't level matched.
I wish everyone would learn, if you don't match levels you have nothing in comparison files. Nothing. I've wasted time on this so many times that is why I saw MP3, probably not level matched, life is too short. I'm only bothering to type this so maybe Maty will understand why we didn't listen to his files. I don't think Maty was trying to mislead anyone. It is too easy to mislead oneself. So check for level matching on things like this.
maty
maty
Tarragona (Spain)
You do not want to understand. Although the two red fruits are very different and not normalized, their taste is so different that a person immediately appreciates the difference. Same here with the clips from the three DIY amps.
In music, regardless of the sound quality, Elvis rock and roll and current reggaeton are easily differentiable.
Blumlein 88
Okay let us go with this. I compare files from a 250 watt SS amp and 3 watt SET both driving an average low efficiency speaker. Could I hear a difference in those without level matching? Most likely I could. Does this surprise me or inform me in some new way? No not at all. I would have expected that difference. A waste of time on something obvious.
I'm continually amazed and mystified as to why it is so hard to get people to simply match levels. It is so easy to do. I also find if someone balks at this thinking it unimportant, then I really am wasting time on any of their experiments.
maty
maty
Tarragona (Spain)
What you comment would be the required if the comparison were from FLAC vs MP3 or WAV or 16/44 vs 24/96 or similar tests.
Blumlein 88
No level matching is a job #1 critical step in comparing anything in audio. Plus if you skip this step nothing else you do is telling of anything involving listening to things.
maty
maty
Tarragona (Spain)
The only valid conclusion of the test, with those three DIY amps, is if we are able to differentiate sound profiles, with the same audio quality, low.
Not if one is better than another, for which yes it would have to be a much more rigorous test, of course.
The song Always on my mind is easily distinguishable between the Elvis version and that of Pet Shop Boys, even if it was an MP3 at 128 kbps or worse, the rhythm is different.
SIY
Alfred, NY
They're different levels, so of course they can be differentiated.
How many people have to tell you that you have not set up a correct experiment to answer the question you have, before you start thinking, "Maybe I made a mistake and ought to listen to the good advice I've gotten?" If the answer is, "I will never, ever admit error and try to do things correctly," then I think you should not be participating in an actual technical forum.
pkane
North-East
They are different because they are at different levels. That’s all anyone here needs to know. Any other comparisons or conclusions cannot be made until you match levels.
maty
maty
Tarragona (Spain)
But nobody has commented yet that differentiates them or not.
pkane
North-East
Because everybody who has done controlled testing before knows that it’s not worth the time to A/B non-level matches tracks. It is a foregone conclusion that the louder track will sound better/different. Why would anyone want to waste their time?
