killdozzer
Damn you Amir, you make me crave so many things I never knew I needed!
Ahh! MQA, why ? That ship sailed years ago. Help keep our signal paths clean, say no to MQA.
Wait no more, it seems they're releasing a major redesign of the BHD non-Pro, with BAL and SE outputs (not just BAL and not 2.5mm), same SNR and max power as the Pro, advertised THD+N=0.0004% (better than what Amir measured for the Pro), no MQA (thank you!), added 3-gain button and lower price (at least if you apply all the 11.11 discounts while the event is still on): https://www.aliexpress.com/item/1005006195974359.htmlSame. waiting for a cheaper mqa-free version/competitor.
Sure, if you mean it's like every other scam technology that's been promoted based on promising things it doesn't deliver (i.e. lossless reproduction). And just like every other scam technology it should bring shame and public condemnation on everyone promoting it, especially those who are also trying to profit from it.MQA is a technology like any other.
OOOK!Sure, if you mean it's like every other scam technology that's been promoted based on promising things it doesn't deliver (i.e. lossless reproduction). And just like every other scam technology it should bring shame and public condemnation on everyone promoting it, especially those who are also trying to profit from it.
Also this dac doesn't support Android 13 and 14
It doesn't?Also this dac doesn't support Android 13 and 14
Yes, I try with different devices on Android 13 Build (USB Exclusive Mode doesn't work) Get disconnectedIt doesn't?
Works beautifully with my Samsung Galaxy 20FE under Android 13 running exclusive mode in Tidal, UAPP and HiByMusic apps. Recheck your USB C to USB C jumper cable.Yes, I try with different devices on Android 13 Build (USB Exclusive Mode doesn't work) Get disconnected
I have jcally and stock cable still same issue with A13 but working fine on Android 11 and A12.1 lolWorks beautifully with my Samsung Galaxy 20FE under Android 13 running exclusive mode in Tidal, UAPP and HiByMusic apps. Recheck your USB C to USB C jumper cable.
Stop playing, refuse to play the next song The LED is red without changing.Also this dac doesn't support Android 13 and 14
I could access that link on Nov 30. That's when i got the firmware hereAnyone else notice when you attempt to access the firmware, it directs you to Google Drive which states, "We're sorry. You can't access this item because it is in violation of our Terms of Service"?
Also, the device doesn't work with the USB C to Lightning cables I have from FiiO and iFi cables, which otherwise are compatible with many USB C DAC/Amps I own. I'll have to order Tempotec's cable from AliExpress (which, BTW, why do they always charge me sales tax, when you can bet your a$$ they're not sending NJ the sales tax they collected).
I think I'm done with these lesser known Chinese brands, and stick with the more established companies.
