TempoTec Sonata BHD (non pro) volume control issues under Windows 10
avm
Hi there!
I was wondering if someone else has experienced this issue with this Dongle/dac: I can't control the volume properly/gradually with Windows 10. It's either 100% volume (starting at 2% and higher) or 0% (at 0%). I'm a bit disappointed since I also own the BHD pro version and it doesn't behave like this.
Is there anything I can do about it?
Cheers.
My Tempotec BHD DSD is the same, but I usually adjust the computer to 100% for a DAC/Amp with independent volume control.
It seems that this is a problem not only with this DAC, but with other manufacturers too. Sometimes the connection gives smooth adjustment in the Windows environment, and sometimes the result is "yes-no", 0% silence and 1-100% sound just at the same level. I read that this is due to two connection modes - USB Audio Class 1.0 (UAC1) and USB Audio Class 2.0 (UAC2). However, I do not know much technical information.
