Jim Taylor
- Joined
- Apr 7, 2024
- Messages
- 1,322
- Likes
- 4,478
And there is the problem, right there.A lot of speaker design is based on guesswork and speculation anyway.
But there is no evidence that it does. None. Literally....None.if it does what they say, there has got to be a reason, an effect, for it.
See point 2What effect are you suggesting would do it?
Pure, 100% speculation. That's what gets engineering into these messes in the first place....because I'm not sure what your actual contention is. My contention is that the designer did the maths: 6>1, and correspondingly, you might find a greater surface area of coil windings. Plus it might cool better spread between 6 motors. So, I'm not sure how wrong I am when I am not advocating the technical argument myself, just explaining what might be the design intention.
I rest my case... yer onnerI'm not in the habit of reverse-engineering goofball designs inside my head, but I guess I am now.
...but I'm just speculating and playing Devil's Advocate for a rational based on some science-y thing that the designer-"engineer" might have had in mind. A lot of speaker design is based on guesswork and speculation anyway
A lot of speaker buying is based on guesswork and speculation… This I would agree!A lot of speaker design is based on guesswork and speculation anyway.
On the one hand this is an area of mature technology, where most ideas, good and bad, have been tested, and Darwin has done his thing. There's little to be had but slow and incremental improvements, mostly through application of work from other areas, materials, modeling software, what have you.I think it's about driver mass, in relation to magnet's surface area on the coil, if I had to guess. Let's say that total driver mass is identical, I'm pretty sure six magnets and coils can move it with more control than a single coil.
We all just need to accept that kit ends. Reproduction is engineering, not art. We all need to buyrecords, more records, bigger houses to accomodate our records.recordings. And we need to get off our asses to hear live music. Musicians are the artists, not some schmoe with a HiFi brand.
No need for reverse-engineering, if it delivers what is objectively good sound measurements, it is a succeessful design, we won't care if it's made of a dozen toilet paper. I believe a lot of ppl here would be convinced if it objectively performs ignoring the look or array, but if it don't perform, it doesn't matter if it is made out of unobtainium either...but I'm just speculating and playing Devil's Advocate for a rational based on some science-y thing that the designer-"engineer" might have had in mind. A lot of speaker design is based on guesswork and speculation anyway. I'm just trying to fix that concept to a plausible effect. Six coils verses one? if it does what they say, there has got to be a reason, an effect, for it.
What effect are you suggesting would do it? ...because I'm not sure what your actual contention is. My contention is that the designer did the maths: 6>1, and correspondingly, you might find a greater surface area of coil windings. Plus it might cool better spread between 6 motors. So, I'm not sure how wrong I am when I am not advocating the technical argument myself, just explaining what might be the design intention.
Well for me - it would have to justify the arrays existence, not just by performing, but by performing better than a traditional design (otherwise the cost and other compromises are not justified).I believe a lot of ppl here would be convinced if it objectively performs ignoring the look or array,
No offense, I am personally more open, if gimmicks or a diffent approach did achieve what is desired, it's a good design, the extra cost is just kind of R&D cost in my book, there's no harm to pay extra for some gimmicks/look where one would get more satisifaction, but if one need to trade performance for the gimmick/look, then it is going into the wrong directionWell for me - it would have to justify the arrays existence, not just by performing, but by performing better than a traditional design (otherwise the cost and other compromises are not justified).
Problem is if they are selling the array based on "speed" it is nonsense. All designs that achieve flat FR also achieve "speed", and you don't need daft looking, expensive, beaming tweeter arrays for the mid range to get that.
That is fine - we are a broad churchNo offense, I am personally more open
That's a lot of money freed up right there.FIFY.
Jim
Thank you @amirm
As much we may understand Eric’s point of view that a minor cabinet leak can, and will change the port turning, and measuring on a different axis will affect the measurement, I feel that the owner’s reaction was unnecessary.
The approach to critical feedback can be managed in a different way.
After all, this is not the same magnitude of problem like a gross error- like a driver being wired out of phase, or a damaged / non-functioning driver.
I would have thought that a different approach would be more constructive eg. Reflecting on limitations of being able to control a user’s set-up process (eg. not installing feet) or listening on the tweeter axis instead of the woofer axis.
I would think this is a better approach and better for public relations for all involved.
After all, Eric does seem to have other interesting designs worthy of audition / measurement / review.
t![]()
Ulfberht
“The Tekton Ulfberht is a surprisingly good speaker in traditional high-end audio terms.” —Tom Martin, The Absolute Sound Named after medieval-era Viking swords, the Ulfberht loudspeaker is the…tektondesign.com
What speakers do you use?The empire strikes back.
The clash between Tekton and the objectivistas will not be fought out in a court. Because then the judge must decide between the value of objective and subjective opinions in HiFi.
There are some examples of gear where everything comes together. One of these is making beautiful music now in my room: the Chord Dave dac. Together with a streamer with a much better sound than the bit-perfect MicroRendu (Bryston BDP-2) every day I understand better that measurements do not say everything. Between measurements and the best sound is a gap.
And that gap is where this fuzz is all about.
I feel sorry for your bank balance. But I wish you well in your pursuit of expensive distortion machines.The empire strikes back.
Indeed. I guess they have never heard of a wave guide….lol. Amazing thing those wave guides. A piece of plastic or metal, properly designed takes care of everything claimed for the radial tweeter array.I think I understand the idea behind these designs - using a bunch of tweeters in parallel in order to extend the lower limit of their range down into the midrange with the idea that using a bunch of small drivers instead of one larger cone or done will offer an advantage in terms of diaphragm control - many voice coils per square area of driven diaphragm surface - so why not use an electrostatic driver, which is controlled over 100% of it's diaphragm area? Or a magnetostat driver of some description? The multiple tweeters are apparently crossed over at 300 Hz and only the central tweeter is crossed at 1,000 Hz, so that array of little drivers is acoustically one large driver at midrange frequencies.
I would worry about distortion - small drivers tend to have high distortion below their intended range, though maybe paralleling a bunch of them avoids this.
I just don't see the advantage here, except to offer "something different."
