Technics SB-5000a tweeter upgrade
creeljd58
Can anyone recommend a good soft dome tweeter to replace the old cone driver?
The Morel CAT378 is probably the best Morel choice for this application because of its built-in waveguide and higher efficiency, making it a better match for the Technics SB-5000A's high-sensitivity design.
The Morel MDT29 is also an excellent soft dome tweeter with a smooth, refined sound, but its lower sensitivity makes it a less ideal match. Neither Morel is likely to be a true drop-in replacement. Even if the mounting dimensions fit, the acoustic response, sensitivity, and impedance characteristics will differ from the original 60 mm cone tweeter.
Other candidates worth considering are Wavecor TW030, SB Acoustics SB26/SB29, classic Vifa soft domes such as the D27TG or XT series, Audax TW025/TW034, or Ciare dome tweeters. These are more in line with the efficiency and character of a vintage Technics design.
Whatever tweeter is chosen, expect crossover modification, L-pad adjustment, and final tuning by measurement. The best replacement should be selected by acoustic performance and integration, not only by physical fit.
A literally out-of-the-box answer:
ESS Great Heil AMT, $250 per pair. Place it on top, and use it dipole above 1K. Original crossover was spec'ed at 2K. Regardless of the tweeter you choose, you should measure and adjust the crossover accordingly. REW and a USB mic would do. Tweeters Michou listed above are good choices as well. There are some buyouts of Wavecor tweeters now, that could be worth a look (see https://www.cinergyaudio.com/collections/tweeters). Note that there will be a directivity mismatch between a 10" and any tweeter that is not in a large waveguide. The dipole tweeter I suggested (sort of) reduces that.
I don't have a specific recomentation for this speaker but I have done this type of relpacement on several speakers. I would check other forumns in addition to this one for ideas. I would look for a tweeter that fits and has similar size dome and electrically has a similar DC resistance. Then use an adjustable L-pad to adjust the level, preferably using measurements. This should get a reasonable integration without having to redesign the crossover. After you are satisfied with the sound you can either measre the values of the variable l-pad and replace with resistors or leave the variable l-pad.
