I noticed that DIYs aren't interested in low power amplifier. After all, the TPA3110 in ABD modulation with 2x30w@4 ohms is unbeatable for SQ, costing less than $25.
To save my innovation of transforming class AB into class A type exempt of crossover distortion, I made the TDA7293x6 in differential, single 48v supply to pour 250w@4 ohm.
It works with 2 masters, on PCB and 4 slaves on heatsink. It can be single ended input or differential. The size of the PCB will be 100x75mm to cost $4/5pcs
To start with, I will keep as simple as possible to check for sound quality and add extra components if needed, as Jfet input buffers for example.
All components are standard THT for low cost and DIY friendly.
