TASCAM CD-200 Review (CD Player)
The Tascam CD-200 was/is available in the following versions:
CD-200
CD-200BT (Bluetooth and Line-In)
CD-200SB (SD/SDHC Card & USB Input, Balanced Audio Output, Extended Keypad with 10-Key Keypad)
CD-200iL (iPod Dock with Lightning and Line-In) Discontinued
CD-200iB (iPod Dock, Line-In and Balanced Audio Output, Coaxial and S-Video Output) Discontinued
CD-200i (iPod Dock and Line-In, Coaxial and S-Video Output) Discontinued
All CD-200 models are equipped with the TEAC CD-5020A CD drive, as are the TEAC PD-507T CD transport and the 505T and 507T CD players.
This overview should serve as a guide for anyone considering buying a new or used unit.
I cannot say whether the underlying drive control is the same or has been further developed, but the current CD-200 and the longest discontinued CD-200i both appeared in 2009; all other devices came out after that.
Every transport differs in sound quality and presentation most of the time.
Most of the time ? Say, even at equal prices ? Cause the saying was better sound but at 10x the price, up to now.
Can you describe the different sound quality for 5 different transports ?
Do you know of a single test that has proven anything like that?
And how would something like that even work technically?
This data is completely digital; how could the sound be selectively altered without DSP?
We conducted such measurements 25 years ago, and even back then, no difference was detectable when comparing the extracted data, regardless of the price range.
Over the last 15 years, we've also carried out completely blind listening tests with drives and CD players in various price ranges up to €20,000, and the result was 6:4 for the €100 player with a digital output against the €20,000 drive. But that's just a random result because all participants in the blind test could only guess.
As long as the drive isn't defective or the data isn't manipulated afterward, where would any audible differences come from? Except, of course, from one's own imagination in an unblinded test.
Incidentally, there is reliable data on tens of thousands of CD drives that read audio data flawlessly when ripping CDs; among the best drives are even some notebook drives costing €20-30. What could possibly be improved in a drive costing €20,000 or more?
100% of data cannot be improved.
So true but one needs to know the basics of digital and signal processing to understand.
And if we were to accept audible differences from one drive to another, HDCD would have never existed, since it uses the last bit of subsequent PCM 16bits subframes to provide instructions to the HDCD decoder. So, being that precise require all drives to be bit perfect (at least trying to).
Like you said, only DSP can consistently alter the sound, in a coherent manner.
I just got my Tascam CD200 and it's better than the Onkyo C-7030 and the Pioneer PD-10AE. It easily outperforms them.
But I smell the burning smell on the disc, is this OK?
Somehow, something has gone wrong for me once again.
Ever since @NTTY’s review of the Tascam CD 200, I’ve been on the lookout for an affordable used unit. In the process, I noticed that there are—or were—a total of six models/variants of the CD 200.
In any case, I now have two CD 200 units sitting here: a CD 200SB and a CD 200iB :facepalm: .
One thing I can say right off the bat is that the CD 200 is the oldest unit in the series, and it is still being manufactured today. All other CD 200xx models—whether discontinued or still available—are essentially the same devices; they feature the same drive mechanism, the same mainboard, and the same keypad on the right-hand side, and as CD players, they all share the exact same basic functionality.
Any additional functionality is achieved exclusively through different keypads on the left-hand side and via add-on boards for those extra features; otherwise, all CD 200xx models are absolutely identical in construction to the standard CD 200.
Performance as a Drive and CD Player:
I own an extremely large collection of CDs featuring high-quality music spanning a wide variety of genres. Naturally, this includes some CDs that tend to give certain CD players or transports trouble. This ranges from a 1989 DMP sampler all the way to the truly excellent *NAGRA 70TH YEAR ANNIVERSARY COLLECTION ALBUM*.
The Shanling CR60—which I originally purchased as a desktop transport over a year ago but subsequently returned—was actually unable to play any of these specific CDs, which otherwise only caused sporadic issues on other systems. To this day, this issue has not been resolved, even via firmware updates.
The Tascam CD 200 plays all of these CDs absolutely flawlessly. There are no issues during the disc-reading process—no read errors, dropouts, clicks, etc. Gapless playback also works absolutely perfectly, even with CD-Rs and the CD layer of SACDs. The Nagra CD caused audible issues on the CR60 during the final track (the CD has a runtime of approximately 65 minutes)—problems that actually intensified toward the end. The strange thing was that these same artifacts were also present on the rip I created using the CR60 onto a USB stick. Naturally, everything was perfectly fine when ripping the CD using a standard computer drive.
The Tascam CD-200SB—which also features a ripping/recording function for USB drives and SD cards—produced a flawless rip of the Nagra CD.
The CD-200iB performed just as excellently.
I was also deeply impressed by its mechanical robustness.
Whenever I acquire used equipment—regardless of what it is—my first step is to clean it thoroughly. As a rule, I perform this cleaning while the unit is powered on and running (please, under no circumstances attempt this yourself unless you are fully knowledgeable about mains voltage and the associated hazards). So, with the CD playing, I cleaned the entire exterior of the unit, lifting it on all sides by at least 45 degrees in the process. On two occasions, its feet even slipped over the edge of the table, causing it to drop about 2 cm—yet there were absolutely no issues, no dropouts whatsoever. I also lifted it—both on one side and on both sides simultaneously—and set it down hard from a height of 5 cm several times; again, not a single dropout. Until now, I had only ever encountered this level of mechanical resilience in high-quality portable CD players (Discmen) and car CD players.
In my experience, this is—by far—the most mechanically robust and compatible drive I have ever encountered. And that is saying something, considering I have handled several hundred CD players and drives across all price ranges over the course of more than 37 years.
I've been looking at the Cambridge Audio CXC V2, would this be a superior transport? My DAC is the RME ADI-2 DAC fs, my audio rack is a server rack, so I could mount it also.
The CXC (V2) is a great transport; it has been running very reliably for me for two years.
The Tascan CD200 is no worse, probably even slightly better, because it is even less sensitive.
I’ll be replacing my CXC with a Tascam CD200 in the coming months.
The look, feel, and usability vary greatly; everyone has to decide for themselves.
This has been a great read. Thank you for the review from a few years back. I'm strongly considering the Tascam 200-BT and using it as a transport. I currently have an old and still pretty reliable California Audio Labs CL-10 that I bought from E-Bay for $250. It replaced my Cal Audio Labs CL-5 that I paid $995.00 back in 1999, both are 5 disc tables which is nice if you are lazy. The CL-10 is HDCD which in my experience with the same recordings back to back (Standard vs HDCD) does not improve the sound audibly or at least the discs I have don't yield an audible sound quality difference. I find very good recordings on standard CD to sound great and there is not a huge benefit from the HDCD format.
I have actually enjoyed recordings in "Q-Sound" more than anything on HDCD.
Anyway, reviews like these and reviews of cables have really set me on a different path.
I still have "high end" "supposedly" components perhaps, (Bryston) but there is a member here with the handle of MAB, that measured his older Bryston gear, did a full review with measurements, and he found the stuff very good, especially since his amps were near 30 years old. I don't find many in the "audiophile crowd" that like Bryston which makes me feel like it is probably decent equipment the DAC on my preamp will be what I plug the Tascam into should I go that route. This review highlights what I'd want out of a player as a transport. Reliability, able to read scratched or worn discs, and a rugged build that makes a produces a player that should last a long time with proven innards that don't break down easily.
Anyway, I think the next easy change to my system would be this player. Based on this review and some comments here, it sounds like a great transport.
Hello Everyone,
This is a review and detailed measurements of the TASCAM CD-200 professional CD Player and Transport.
TASCAM CD-200 - Presentation
This player has been a member of the TASCAM family for quite some time, and is still available from your preferred local resellers. Once upon a time, there was a version with an ipod slot :) I don't know if the internals have always been the same or if they've been updated. I will not open the one I have else it would void the warranty, sorry for that.
The price is reasonable, I think, lower than many entry level CD Players. That's why I went for it, If it'd perform well, we'd have some sort of a bargain here.
We find everything we need on the front face and I like a lot the buttons that are easy to identify. The feel and touch is not luxury, but mechanically reassuring. There's a phones out and I always appreciate that. There's a remote control too, of course.
You see that the pitch can be adjusted, but that is not by step, it's rather a analog way (understand non-discrete) to adjust it, so it's very difficult to be precise.
The back is standard and shows the essential:
We get two digital outputs, on top of the RCA analog outs, and that should be enough for a lot of us.
The drive is fast, absolutely no frustration here compared to a good old CD player, that's a good start. FFW and REW are also efficient, and that's a key feature to me when I run my tests, so trust me if I say it's more than good.
So, that first encounter with the TASCAM is positive.
TASCAM CD-200 - Measurements (Analog outputs)
All measurements performed with an E1DA Cosmos ADCiso (grade 0), and the Cosmos Scaler (100kohms from unbalanced input) for analog outputs, and a Motu UltraLite Mk5 for digital.
I am now consistent with my specific measurements for CD Players, as I described them in the post “More than we hear”, and as I reported them for the Onkyo C-733 review. Over time, this will help comparing the devices I reviewed.
As per its specs, the TASCAM outputs 6dBV, that is 2Vrms. The tow channels matched at a low 0.05dB, which is very good. The unbalanced outputs are non-inverting.
As usual, let's start with my standard 999.91Hz sine @0dBFS (without dither) from the Test CD (RCA out):
The distorsion is higher than the best in class, but at -91dBr, good luck to hear that. The level of THD is what limits the ENOB, but SNR is still good with that full scale test tone (95.2dB). Note some side rays around the fundamental, they are due to an interaction with the power supply. At -110dBr, they will remain hidden to your ears, of course.
Let's run the same test at -6dBFS as I'm used to:
Good news, the distorsion went down by a good margin. This player, like so many others, does not like much playing full scale test tones. Anyways, this is a more than good result. With a lower test tone (-6dBFS), the SNR improved (90.5dB +6dB = 96.5dB).
I think you saw some PS leakage;
We get some spikes at 50Hz (Europe), and 150Hz + 250Hz, but they are at a very low -120dBr, not a concern. This view allows you to better see the interaction of the PS with the fundamental: look and these spikes at 800Hz, 850Hz, 900Hz and 950Hz. Again, these are very low and so close to the fundamental that it is impossible to hear.
Next is the bandwidth:
Despite the zoom, this is very flat. We can see the beginning of ringing at the end of the bandwidth, an indication of a low performance oversampling filter. And so, let's have a look at how it performs beyond 20kHz:
Oh, only -50dB attenuation and a significant ringing (red trace), like what we had from the early oversampling filters, some 40 years ago. And if there's a sound from the 80s related to the way their digital filtering were performing, well... you get it here!
A touch of modernity is to note, though, the ramping up of noise floor that you see beyond 30kHz is due to the noise shaper of the filter/DAC (obviously equally low performing 3rd order noise shaper, I'd say).
Let's have a look at the multitone test that a lot of you like very much:
Nice, the TASCAM has no issue to play complex test tones with much more than 17bits free of distorsion. No need to ask for more.
Let's move on to the jitter test:
The red trace is from the digital output of the TASCAM, and is perfect. the blue trace is from the RCA outs. It shows a little more low level noise floor than the best in class, and very low level lateral spikes. This is way below what anyone can hear, and so that is good.
Started with the Teac VRDS-20 review, and on your request + support to get it done (more here), I'm adding now an "intersample-overs" test which intends to identify the behavior of the digital filtering and DAC when it come to process near clipping signals. Because of the oversampling, there might be interpolated data that go above 0dBFS and would saturate (clip) the DAC and therefore the output. And this effect shows through distorsion (THD+N measurement up to 96kHz):
Intersample-overs tests
Bandwidth of the THD+N measurements is 20Hz - 96kHz
5512.5 Hz sine,
Peak = +0.69dBFS
7350 Hz sine,
Peak = +1.25dBFS
11025 Hz sine,
Peak = +3.0dBFS
Teac VRDS-20-30.7dB-26.6dB-17.6dB
Yamaha CD-1-84.6dB-84.9dB-78.1dB
Denon DCD-900NE-34.2dB-27.1dB-19.1dB
Denon DCD-SA1-33.6dB-27.6dB-18.3dB
Onkyo C-733-88.3dB-40.4dB-21.2dB
Denon DCD-3560-30.2dB-24.7dB-17.4dB
Myryad Z210-70.6dB (noise dominated)-71.1dB (noise dominated)-29.4dB (H3 dominated)
Sony CDP-x333ES-30.5dB-24.8dB-16.3dB
BARCO-EMT 982-32.7dB-24.5dB-16.3dB
TASCAM CD-200-73.5dB-36.3dB-19.7dB
I kept some references and will keep the same for other reviews, so you can quickly compare. The results of the TASCAM CD-200 mean that it has 1dB headroom in the oversampling filter, which is to appreciate, I think.
Let's continue with the good old 3DC measurement that Stereophile was often using as a proof of low noise DAC. It is from an undithered 997Hz sine at -90.31dBFS. With 16bits, the signal should appear (on a scope) as the 3DC levels of the smallest symmetrical sign magnitude digital signal:
This is a good trace and proof that at low levels, this player offers a very good resolution, and this is much better than the Sony CDP-X333ES.
At this lowest symmetrical level in 16bits PCM, we expect to see a square only, as it is no longer possible to represent a sine. The ringing is due to the Gibbs Phenomenon and the reconstruction filter which is symmetrical:
Other measurements (not shown):
  • IMD AES-17 DFD "Analog" (18kHz & 20kHz 1:1) : -78.1dB
  • IMD AES-17 DFD "Digital" (17'987Hz & 19'997Hz 1:1) : -78.2B
  • IMD AES-17 MD (41Hz & 7993Hz 4:1): -81.9dB
  • IMD CCIF (19kHz & 20kHz 1:1) : -78.1dB
  • IMD DIN (250Hz & 8kHz 4:1) : -76.1dB
  • IMD SMPTE (60Hz & 7kHz 1:4) : -76.9dB
  • IMD TDFD Bass (41Hz & 89Hz 1:1) : -97.5dB
  • IMD TDFD (13'58Hz & 19841Hz 1:1) : -92.4dB
  • Dynamic Range : 97.3dB (without dither @-60dBFS)
  • Crosstalk: -114dBr (100Hz), -102dBr (1khz), -78dBr (10kHz)
  • Pitch Error : 19'997.65Hz (19'997Hz requested) ie 32.5ppm
  • Gapless playback : Yes
The IMD results are not so good compared to best in class, but will not be heard. The real dynamic range is very close to the maximum of the Audio CD format (.5dB). The clock deviation is below what I see with modern CD players, but again more than good enough for audio (32.5ppm).
As I did with the Sony CDP-597, I add a "max DAC resolution" measurement test. It is performed from a 999.91Hz sine @-12dBFS with shape dither (from Audacity). I restrict the THD+N span to 20Hz - 6kHz in REW not to account for the noise of the shape dither beyond 6kHz. I take the calculated ENOB and simply add 2bits to it (due to the -12dB attenuation, as 1bits=6dB). The potential maximum, when calculated from the digital WAV file, is 18.7bits under this test. A "transparent" DAC should achieve 18.7bits, ie 100% in this test.
Here are the results of the Yamaha compared to others:
CD Player model or DACCalculated ENOB (999.91Hz sine @-12dBFS with shape dither, THD+N span = 20Hz - 6kHz)Percentage of max resolution achieved (higher is better)
OPPO BDP-9518.7bits100%
SMSL PL-20018.7bits100%
SMSL PS-200 (from CD player)18.6bits99.47%
Pioneer BDP-LX5818.5bits98.93%
Denon DCD-900NE18.5bits98.93%
Yamaha CD-S200018.4bits98.40%
Onkyo C-73318bits96.26%
SMSL PL15018bits96.26%
TASCAM CD-20017.9bits95.72%
SMSL PL10017.9bits95.72%
Sony CDP-59717.5bits93.58%
Onkyo DX-735517.3bits92.51%
Denon DCD-356017.2bits91.98%
Yamaha CD-S30316.8bits89.84%
Revox B-226S16.8Bits89.94%
Accuphase DP-7016.6bits88.77%
Sony CDP-337ESD16.6bits88.77%
Teac VRDS-25x16.5bits88.24%
Marantz CD-7314.9bits79.68%
The TASCAM scored well is that test which is reassuring.
Last and not least, I like to run a THD vs Frequency sweep at -12dBFS as it shows how the conversion has evolved over time. I am currently using the beta version of REW and I discovered that this sweep gives better and more reliable results than before. I overlaid the results of the two channels with one from the Denon DCD-900NE, to compare:
The right channel of the TASCAM has little more distorsion than the left one. The THD is a bit higher than best in class (Denon DCD-900NE), and more than decent since it is buried below the noise floor.
TASCAM CD-200 - Measurements (Digital Coax Out)
I've seen several of you reviewing CD players using their digital outputs, in case the results could be improved from an external DAC.
So let's go with the 999.91Hz @0dBFS:
This is as good as what I can measure, meaning "perfect" digital output.
The 3DC test that I like to run in analog, is also "perfect" here:
This, to me, means no significant digital change at the digital output, ie: the TASCAM CD-200 is a "perfect" CD transport.
I thought about one additional test to add to the digital section, and to verify the data are not modified. It is simply reusing the intersample overs test at 5512.50Hz, with a phase shift of 67.5°. This signal generates an overshoot of +0.69dB and so if the signal would be modified before being sent, it would show either a reduction of amplitude or we'd see some sort of saturation. So here we go, the below is a comparison between the WAV File directly processed by the PC, and when played by the TACSCAM and via the coax out:
The two traces are identical, including the +0.69dBFS that the software sees from the phase shift. This means that the digital data sent by the TASCAM is the same as what it was from the original test WAV File. I think I like this new test :)
TASCAM CD-200 - Testing the drive
What would be good measurements if the drive would not properly read a slightly scratched CD, or one that was created at the limits of the norm? The below tests reply to these questions.
Test typeTechnical testResults
Variation of linear cutting velocityFrom 1.20m/s to 1.40m/sPass
Variation of track pitchFrom 1.5µm to 1.7µmPass
Combined variations of track pitch and velocityFrom 1.20m/s & 1.5µm to 1.40m/s & 1.7µmPass
HF detection (asymmetry pitch/flat ratio)Variation from 2% to 18%Pass
Dropouts resistanceFrom 0.05mm (0.038ms) to 4mm (3.080ms)Pass
Combined dropouts and smallest pitchFrom 1.5µm & 1mm to 1.5µm & 2.4mmPass
Successive dropoutsFrom 2x0.1mm to 2x3mmPass
The TASCAM CD-200 is the first drive I tested to pass all tests. The interpolation kicked off with 2.4mm dropouts but remained hidden to my ears. The below is a measurement of the RCA output when it is interpolating vs when it's not:
Note that most of the drives I test do not play at all the track with 4mm dropouts, either simply stopping playing or skipping few seconds with massive "clicks" that can be heard before failing. Actually, many fail with 3mm dropouts too.
Of course the CD-200 had no issue with variable linear velocity and/or track pitch, as well as with HF detection. And again it is the first player I tested to successfully play the track with consecutive 3mm dropouts. Impressive.
Conclusion
This is a decent performing player and a perfect transport. The clock deviation (35ppm) will transition to a DAC, but you won't be able to hear it.
The performances we get from the analog outputs are enough, all limited by harmonic and intermodulation distortion. All can be improved from an external DAC.
Considering the price, and the physical performances of the drive that can read CDs with holes into them, I think this is a nice CD player and an ideal transport.
Hi folks!
I've just been rereading this wonderfully detailed review from NTTY and came upon the following info in the conclusion which gave me pause for thought:
"Conclusion
This is a decent performing player and a perfect transport. The clock deviation (35ppm) will transition to a DAC, but you won't be able to hear it."
I was intrigued enough to look into the consequences of this deviation with regard to time and pitch, and here is what I discovered:
"A clock deviation of 35 ppm (parts per million) translates to a long-term time drift of 35 microseconds (μs) per second, which equals 126 milliseconds (ms) per hour.
This drift is entirely imperceptible to the human ear, as a pitch change of 0.0035% is far below the human threshold of pitch discrimination."
I can rest in peace!
This is all very interesting, as I have been using a pair of TASCAM 6010 Professional CD players for the past 6 years as transports for my primary CD replay, and I believe they use the same 5020 mechanism as the 200 series, they certainly have the same poor display.
I chose them for their perceived professional build quality, reliability and durability and for the AES output (they go into a Grace m905 used as a preamp). I have them racked in a nice solid 6U unit and, as noted above, they have played and read every CD bar one without exception over the years, a remarkable performance.
The 2 problems I have, apart from the weak display, are that they were way over-priced at €900 each - I considered a lot of options but in Oct 2020, they were the best for my setup and I had the money, so bit the bullet.
But much more problematic is the noisy operation - high pitched whine as they read and play the disc, audible to me at 2m during quiet passages of music, grrr! They are silent when not playing, TG.
I could not find any reviews of the players before purchase so bad luck for me. As I am usually blasting tunes, I can live with this flaw most of the time, but I was wondering if the CD-200s also run loud??
Mine is quiet, just little sound when loading or jumping to next tracks, but nothing while playing, cant hear any noise when 1m away.
But I cant hear above ca 13kHz anyway, so maybe just too deaf...
Regarding the aforementioned TASCAM 6010 CD player, I found a particularly nauseating and risible exchange over on Stereonet. In response to someone asking for people's thoughts on the player, I quote:
"The player needs at least 350hrs of continuous running before an upper mid-range sheen disappears and becomes transparent, open, and relaxed. The Bass is initially quite light, and lacking resolution, but gradually begins to become solid, extended, and resolving. As the player approaches the 500hr burn-in mark the player becomes very nicely balanced, transparent, and very nice to listen to music through.
The interesting part is that as the player becomes more transparent it is actually louder yet quieter, extremely relaxing to listen to yet involving, produces an excellent sound stage, and amazingly real/natural tonality/timbre/decay/edge control... very interesting and very nice.
The player definitely needed a good AC cable and the chassis definitely needed some resonance assistance but what a nice player... at least for the money I outlayed in this instance.
I would say that the Tascam CD-6010 is better than the Revox C221 player that I like very much for its staging, and real/natural tonality/timbre/decay/edge control (once it was mechanically and AC cable treated)"
What were they smoking that day I wonder? :facepalm:
Oh yes, I remember those comments now, it was so difficult to find any kind of review in 2020. I had the CD-200 for use as a transport in my sights, since they were released, 17 years ago now! But the lack of AES-EBU out was the deal breaker when I actually came to purchase in 2020. Good to know it’s a solid performer, thanks for the review!
I purchased a used CD 200 almost a year ago and have been using it as my main player since. Hours per day.
The only problem is the poor remote. It looks bad, tiny buttons and only works when you are in front of the player and aiming directly at it.
Otherwise, as other people noted, nice and reliable machine.
The TASCAM 6010 uses the CD-5010B drive mechanism but features a different control system. As a result, the drive spins at significantly higher speeds and generates more noise—a trade-off made solely to enable faster reading.
The drive is designed to withstand the rigors of touring—conditions that could push the mechanism of a CD-200 model to its limits.
You might want to check the TASCAM 6010's firmware version and install the latest update; doing so could help alleviate the problem somewhat.
Please also verify that the pitch is actually set to 0.0%.
Is the volume level the same for every audio CD (Red Book standard), or does it vary with other types of discs or burned CDs?
For living room or desktop use, I would therefore recommend one of the CD-200 models, as their drives spin only at the necessary speed (1x).
CD-200 units are typically whisper-quiet and rank among the quietest drives available.
But "This model has been discontinued in North, Central and South America."
Did they replace it with something?
