TASCAM CD-200 Review (CD Player)
Thanks for the feedback!
May I ask a picture of that scratched CD? The reason I ask is that I wanted to scratch one for the purpose of that test, but I don't how far I should go. If you have one that makes the TASCAM drop in few occasions, that's the max I need to go for, and so it would interesting to see how to somehow replicate that ;)
Thank you!
Thank you!
I tried to but failed... The CD is not heavily scratched and on all pics it looks pristine.
Skipping is in my experience not predictable based on how bad the disk looks. It has to do with orientation of the scratch obviously. With radial scratches less problematic.
But I think the position on the disk is also important. More to the edge seems to be more problematic.
I have a cheap player , THINKYA JA-310, that refuses long (>60 min) CDs with minor damage. It does not play the last part.
Wanted to buy the way more expensive SHANLING ET3 but read somewhere that some have the same issue.
I really appreciate all your efforts! The scratch test is very innovative and important. Ability to play scratched disks may be one of the most important aspect of CD player use in real life.
Thanks for your efforts.
All true.
Thanks and I can’t agree more! :)
Bought my CD200 10 years ago now, for use as a transport.
The only thing it does wrong is set itself to repeat play (sometimes, somehow)
I picked up a used one and unfortunately the lcd display cannot be read if I am looking down at it. If it is at eye level or above, no problem. I set it on a shelf in my office that is slightly below my eye level and I cannot read the display. I seem to be the only one with this issue. Unfortunately there is no contrast adjustment.
No, you're not the only one, it's indeed a problem: I too can't read on the screen if the player is at the bottom. So to read I positioned the CD 200 in my cabinet at eye level, but depending on my position in front of the screen, the text is not very contrasted. For your information, I bought the player new and the screen has always had this defect.
And yet from the front it is perfect = GRRRRRRRrrrrrrrr :mad: (Tascam Image)
Thnx for a nice review, and for the compilation of CD players tested. Very helpful. If I had one simple wish it would be some measure of mechanical noise and loading time.
Thank you!
Loading time, I now provide that value, but I might forget sometimes. Mechanical noise, yes I mention if I can hear, but I don't measure. When I did once, with the noisiest mech I encountered, I could not measure anything past 1.5m, as the noise was buried under the noise floor of my (quiet) room, so I just gave up.
Loading time, I now provide that value, but I might forget sometimes. Mechanical noise, yes I mention if I can hear, but I don't measure. When I did once, with the noisiest mech I have, and I could not measure anything past 1.5m, as the noise was buried under the noise floor of my (quiet) room, so I just gave up.
I didnt mean measure measure, but some players make that whirring sound when spinning.
Ah ok, yes indeed and I try to mention that when I don’t forget ;) (but I forget to mention only when I did not notice spinning noise).
Recently the Yam CD-S2000 & Pio PD-D9 suffered that small (identical)whirring sound. Older CD player are often completely silent like the Sony CDP-559ES.
I had a Sony SCD-XE800 CD-SACD player; it was noisy and slow, but the sound was very, very good.
The Tascam CD200 sound very good with an external DAC, with its Teac 5020A mechanism, is very quiet. Loading and TOC Read are fast, and switching between tracks is also quick. I have programmable shortcut keys on the front panel of my CD-200SB, and it's very fast there.
Thanks a lot for the excellent review! I've had a project player for a few years now (Sony xe320), and a few days ago too many problems just piled up, so I decided to buy a new cd player for the first time in my life. I made a choice after narrowing stuff down between the Yamaha cd s303, and Tascam cd200. I wanted a very reliable new player with a remote, that wouldn't break the bank with a good internal DAC, and since the Teac laser assemblies are still being made I ordered this. However somewhere I've read you need to be wary about cd players with a built in audio buffer, since some tend to sample it down to mp3 to of course save space, does anyone know if the Tascam just saves the full PCM?
Hello Everyone,
This is a review and detailed measurements of the TASCAM CD-200 professional CD Player and Transport.
TASCAM CD-200 - Presentation
This player has been a member of the TASCAM family for quite some time, and is still available from your preferred local resellers. Once upon a time, there was a version with an ipod slot :) I don't know if the internals have always been the same or if they've been updated. I will not open the one I have else it would void the warranty, sorry for that.
The price is reasonable, I think, lower than many entry level CD Players. That's why I went for it, If it'd perform well, we'd have some sort of a bargain here.
We find everything we need on the front face and I like a lot the buttons that are easy to identify. The feel and touch is not luxury, but mechanically reassuring. There's a phones out and I always appreciate that. There's a remote control too, of course.
You see that the pitch can be adjusted, but that is not by step, it's rather a analog way (understand non-discrete) to adjust it, so it's very difficult to be precise.
The back is standard and shows the essential:
We get two digital outputs, on top of the RCA analog outs, and that should be enough for a lot of us.
The drive is fast, absolutely no frustration here compared to a good old CD player, that's a good start. FFW and REW are also efficient, and that's a key feature to me when I run my tests, so trust me if I say it's more than good.
So, that first encounter with the TASCAM is positive.
TASCAM CD-200 - Measurements (Analog outputs)
All measurements performed with an E1DA Cosmos ADCiso (grade 0), and the Cosmos Scaler (100kohms from unbalanced input) for analog outputs, and a Motu UltraLite Mk5 for digital.
I am now consistent with my specific measurements for CD Players, as I described them in the post “More than we hear”, and as I reported them for the Onkyo C-733 review. Over time, this will help comparing the devices I reviewed.
As per its specs, the TASCAM outputs 6dBV, that is 2Vrms. The tow channels matched at a low 0.05dB, which is very good. The unbalanced outputs are non-inverting.
As usual, let's start with my standard 999.91Hz sine @0dBFS (without dither) from the Test CD (RCA out):
The distorsion is higher than the best in class, but at -91dBr, good luck to hear that. The level of THD is what limits the ENOB, but SNR is still good with that full scale test tone (95.2dB). Note some side rays around the fundamental, they are due to an interaction with the power supply. At -110dBr, they will remain hidden to your ears, of course.
Let's run the same test at -6dBFS as I'm used to:
Good news, the distorsion went down by a good margin. This player, like so many others, does not like much playing full scale test tones. Anyways, this is a more than good result. With a lower test tone (-6dBFS), the SNR improved (90.5dB +6dB = 96.5dB).
I think you saw some PS leakage;
We get some spikes at 50Hz (Europe), and 150Hz + 250Hz, but they are at a very low -120dBr, not a concern. This view allows you to better see the interaction of the PS with the fundamental: look and these spikes at 800Hz, 850Hz, 900Hz and 950Hz. Again, these are very low and so close to the fundamental that it is impossible to hear.
Next is the bandwidth:
Despite the zoom, this is very flat. We can see the beginning of ringing at the end of the bandwidth, an indication of a low performance oversampling filter. And so, let's have a look at how it performs beyond 20kHz:
Oh, only -50dB attenuation and a significant ringing (red trace), like what we had from the early oversampling filters, some 40 years ago. And if there's a sound from the 80s related to the way their digital filtering were performing, well... you get it here!
A touch of modernity is to note, though, the ramping up of noise floor that you see beyond 30kHz is due to the noise shaper of the filter/DAC (obviously equally low performing 3rd order noise shaper, I'd say).
Let's have a look at the multitone test that a lot of you like very much:
Nice, the TASCAM has no issue to play complex test tones with much more than 17bits free of distorsion. No need to ask for more.
Let's move on to the jitter test:
The red trace is from the digital output of the TASCAM, and is perfect. the blue trace is from the RCA outs. It shows a little more low level noise floor than the best in class, and very low level lateral spikes. This is way below what anyone can hear, and so that is good.
Started with the Teac VRDS-20 review, and on your request + support to get it done (more here), I'm adding now an "intersample-overs" test which intends to identify the behavior of the digital filtering and DAC when it come to process near clipping signals. Because of the oversampling, there might be interpolated data that go above 0dBFS and would saturate (clip) the DAC and therefore the output. And this effect shows through distorsion (THD+N measurement up to 96kHz):
Intersample-overs tests
Bandwidth of the THD+N measurements is 20Hz - 96kHz
5512.5 Hz sine,
Peak = +0.69dBFS
7350 Hz sine,
Peak = +1.25dBFS
11025 Hz sine,
Peak = +3.0dBFS
Teac VRDS-20-30.7dB-26.6dB-17.6dB
Yamaha CD-1-84.6dB-84.9dB-78.1dB
Denon DCD-900NE-34.2dB-27.1dB-19.1dB
Denon DCD-SA1-33.6dB-27.6dB-18.3dB
Onkyo C-733-88.3dB-40.4dB-21.2dB
Denon DCD-3560-30.2dB-24.7dB-17.4dB
Myryad Z210-70.6dB (noise dominated)-71.1dB (noise dominated)-29.4dB (H3 dominated)
Sony CDP-x333ES-30.5dB-24.8dB-16.3dB
BARCO-EMT 982-32.7dB-24.5dB-16.3dB
TASCAM CD-200-73.5dB-36.3dB-19.7dB
I kept some references and will keep the same for other reviews, so you can quickly compare. The results of the TASCAM CD-200 mean that it has 1dB headroom in the oversampling filter, which is to appreciate, I think.
Let's continue with the good old 3DC measurement that Stereophile was often using as a proof of low noise DAC. It is from an undithered 997Hz sine at -90.31dBFS. With 16bits, the signal should appear (on a scope) as the 3DC levels of the smallest symmetrical sign magnitude digital signal:
This is a good trace and proof that at low levels, this player offers a very good resolution, and this is much better than the Sony CDP-X333ES.
At this lowest symmetrical level in 16bits PCM, we expect to see a square only, as it is no longer possible to represent a sine. The ringing is due to the Gibbs Phenomenon and the reconstruction filter which is symmetrical:
Other measurements (not shown):
  • IMD AES-17 DFD "Analog" (18kHz & 20kHz 1:1) : -78.1dB
  • IMD AES-17 DFD "Digital" (17'987Hz & 19'997Hz 1:1) : -78.2B
  • IMD AES-17 MD (41Hz & 7993Hz 4:1): -81.9dB
  • IMD CCIF (19kHz & 20kHz 1:1) : -78.1dB
  • IMD DIN (250Hz & 8kHz 4:1) : -76.1dB
  • IMD SMPTE (60Hz & 7kHz 1:4) : -76.9dB
  • IMD TDFD Bass (41Hz & 89Hz 1:1) : -97.5dB
  • IMD TDFD (13'58Hz & 19841Hz 1:1) : -92.4dB
  • Dynamic Range : 97.3dB (without dither @-60dBFS)
  • Crosstalk: -114dBr (100Hz), -102dBr (1khz), -78dBr (10kHz)
  • Pitch Error : 19'997.65Hz (19'997Hz requested) ie 32.5ppm
  • Gapless playback : Yes
The IMD results are not so good compared to best in class, but will not be heard. The real dynamic range is very close to the maximum of the Audio CD format (.5dB). The clock deviation is below what I see with modern CD players, but again more than good enough for audio (32.5ppm).
As I did with the Sony CDP-597, I add a "max DAC resolution" measurement test. It is performed from a 999.91Hz sine @-12dBFS with shape dither (from Audacity). I restrict the THD+N span to 20Hz - 6kHz in REW not to account for the noise of the shape dither beyond 6kHz. I take the calculated ENOB and simply add 2bits to it (due to the -12dB attenuation, as 1bits=6dB). The potential maximum, when calculated from the digital WAV file, is 18.7bits under this test. A "transparent" DAC should achieve 18.7bits, ie 100% in this test.
Here are the results of the Yamaha compared to others:
CD Player model or DACCalculated ENOB (999.91Hz sine @-12dBFS with shape dither, THD+N span = 20Hz - 6kHz)Percentage of max resolution achieved (higher is better)
OPPO BDP-9518.7bits100%
SMSL PL-20018.7bits100%
SMSL PS-200 (from CD player)18.6bits99.47%
Pioneer BDP-LX5818.5bits98.93%
Denon DCD-900NE18.5bits98.93%
Yamaha CD-S200018.4bits98.40%
Onkyo C-73318bits96.26%
SMSL PL15018bits96.26%
TASCAM CD-20017.9bits95.72%
SMSL PL10017.9bits95.72%
Sony CDP-59717.5bits93.58%
Onkyo DX-735517.3bits92.51%
Denon DCD-356017.2bits91.98%
Yamaha CD-S30316.8bits89.84%
Revox B-226S16.8Bits89.94%
Accuphase DP-7016.6bits88.77%
Sony CDP-337ESD16.6bits88.77%
Teac VRDS-25x16.5bits88.24%
Marantz CD-7314.9bits79.68%
The TASCAM scored well is that test which is reassuring.
Last and not least, I like to run a THD vs Frequency sweep at -12dBFS as it shows how the conversion has evolved over time. I am currently using the beta version of REW and I discovered that this sweep gives better and more reliable results than before. I overlaid the results of the two channels with one from the Denon DCD-900NE, to compare:
The right channel of the TASCAM has little more distorsion than the left one. The THD is a bit higher than best in class (Denon DCD-900NE), and more than decent since it is buried below the noise floor.
TASCAM CD-200 - Measurements (Digital Coax Out)
I've seen several of you reviewing CD players using their digital outputs, in case the results could be improved from an external DAC.
So let's go with the 999.91Hz @0dBFS:
This is as good as what I can measure, meaning "perfect" digital output.
The 3DC test that I like to run in analog, is also "perfect" here:
This, to me, means no significant digital change at the digital output, ie: the TASCAM CD-200 is a "perfect" CD transport.
I thought about one additional test to add to the digital section, and to verify the data are not modified. It is simply reusing the intersample overs test at 5512.50Hz, with a phase shift of 67.5°. This signal generates an overshoot of +0.69dB and so if the signal would be modified before being sent, it would show either a reduction of amplitude or we'd see some sort of saturation. So here we go, the below is a comparison between the WAV File directly processed by the PC, and when played by the TACSCAM and via the coax out:
The two traces are identical, including the +0.69dBFS that the software sees from the phase shift. This means that the digital data sent by the TASCAM is the same as what it was from the original test WAV File. I think I like this new test :)
TASCAM CD-200 - Testing the drive
What would be good measurements if the drive would not properly read a slightly scratched CD, or one that was created at the limits of the norm? The below tests reply to these questions.
Test typeTechnical testResults
Variation of linear cutting velocityFrom 1.20m/s to 1.40m/sPass
Variation of track pitchFrom 1.5µm to 1.7µmPass
Combined variations of track pitch and velocityFrom 1.20m/s & 1.5µm to 1.40m/s & 1.7µmPass
HF detection (asymmetry pitch/flat ratio)Variation from 2% to 18%Pass
Dropouts resistanceFrom 0.05mm (0.038ms) to 4mm (3.080ms)Pass
Combined dropouts and smallest pitchFrom 1.5µm & 1mm to 1.5µm & 2.4mmPass
Successive dropoutsFrom 2x0.1mm to 2x3mmPass
The TASCAM CD-200 is the first drive I tested to pass all tests. The interpolation kicked off with 2.4mm dropouts but remained hidden to my ears. The below is a measurement of the RCA output when it is interpolating vs when it's not:
Note that most of the drives I test do not play at all the track with 4mm dropouts, either simply stopping playing or skipping few seconds with massive "clicks" that can be heard before failing. Actually, many fail with 3mm dropouts too.
Of course the CD-200 had no issue with variable linear velocity and/or track pitch, as well as with HF detection. And again it is the first player I tested to successfully play the track with consecutive 3mm dropouts. Impressive.
Conclusion
This is a decent performing player and a perfect transport. The clock deviation (35ppm) will transition to a DAC, but you won't be able to hear it.
The performances we get from the analog outputs are enough, all limited by harmonic and intermodulation distortion. All can be improved from an external DAC.
Considering the price, and the physical performances of the drive that can read CDs with holes into them, I think this is a nice CD player and an ideal transport.
Hello Everyone,
5512.5 Hz sine,
Peak = +0.69dBFS
7350 Hz sine,
Peak = +1.25dBFS
11025 Hz sine,
Peak = +3.0dBFS
Conclusion
I use this unit with a SMSL D6S DAC. Great performance. Excellent imaging and detail. I purchased the unit anxious about the possibility of not having a CD player for my library; the Tascam appears to be a robust unit, which makes me believe it will last a long time. I am impressed positively with its build, functionality, and performance.
Is the TOC-reading-speed as fast as SMSL PL200? Above I read CD-200SB ist fast, but in user forums they say CD-200 (without SB) ist very slow in reading. Thanks for Infos.
I've got my 200 (non-SB) for a few days now, and I find TOC to be pretty speedy. I had a sony xe320 and m205 before, and this one is about ~15-25% faster. With a cd with 16 tracks on it it takes about 3 seconds (after the sled closes, and the laser is in place).
I have a Tascam CD-RW901MKII CD Recorder/Player.
I'm wondering if it has similar drive mechanism.
Hi, I purchased the Tascam CD 200 player and I have to say I'm satisfied. I just have one question: would an external DAC improve the quality or is it worth it? And if so, which DAC would you recommend? Range 100-200 max. Thanks.
