Targets for Dirac Live
I use the same curves for all speakers, including subwoofer. I assume they work the same in the room, regardless of sound material they get form a multichannel track.
I had Audyssey for a short time. The extra tuning of Dynamic EQ was that it increased volume of rear channels. Maybe maybe there was a reason for this, it kind of exaggerated sound effects in movies, but it felt unbalanced, when I moved my head or changed listening position.
Yeah, if one thinks about what the target curve produces, there is no sense in having them different. Unless hypothesis are made regarding what source material does (but source material always behaves differently, even more so if one considers 5.1 and Atmos music content).
I exchanged several emails today with somebody at Dirac customer service. I couldn't get a straight answer to why Dirac uses different target curves by default. He suggested I use one curve for all speakers, as everybody suggested, but when I asked why Dirac doesn't do that by default, I got nothing. Either it's a big secret or they just screwed up and don't want to admit it.
The Dirac guy tried to sell me the thing about no target curve can be good for all content and SPL, and that i have to chose different curves for different purposes. That's not a good reason for not setting by default a decent tune, like Auddissey. When they advertise Dirac, they should state you need to buy a UMIK mic and play with REW in order to get something reasonable at any volume below 85db. If they did, I bet you a lot of people would turn around and buy AVRs that come with Auddissey, instead.
Not to mention that Dirac costs more than Auddissey, when you take into account the fact that Auddissey is included with the AVR, while Dirac is an addon for some AVRs. My Integra AVR came with Dirac Live. If I had to pay for it, I would kick myself.
Does it? I didn't notice that when I went through it, if so. In any case, it's simple to select all the speaker groups and apply the same curve so not a big deal IMO.
Uh, what? They plainly advertise you need a measurement mic if the device doesn't include a suitable one in the box, but you certainly don't need REW unless you want to check the results for yourself. You'd need the same to check Audyssey's results.
Audyssey has its own issues (default BBC dip, only XT32 has enough resolution in the bass to do a proper correction, need to buy the app to get rid of the dip and apply a curtain to the correction). It's also nowhere near as sophisticated as Dirac, though with XT32 and the app you can get acceptable results.
Dirac could stand to be easier to use, sure, but on the other hand we already have DSP enthusiasts around here who proclaim it's too automated as it is.
It does (see attached).
That's not the point. The point is that the automated tune is not useful.
I was talking about the need to try various curves until you get something that works. Auddisey tune was decent (not perfect) without needing to do anything else (I had MultEQ XT32 on my old Denon).
The mobile app is cheap, but it's hard to adjust the target curves with it. The PC app is more expensive.
I'm not saying it's hard to use. I'm actually asking for more user control. I don't know why they don't let me adjust the delays and the crossovers in the Dirac app.
The one obvious thing Dirac could do, since they don't have DEQ, is to do the tune for a given reference level, defined by the user.
That's weird, and not one of the complaints I can recall about Dirac (I've gone through many pages of the main Dirac thread on AVSforum). I'll have to take your word for it, since again I don't recall that being my experience. I didn't see any curves with a bass boost when I got to the filter step until I put them in myself. In any case, yeah that's not a useful behavior when the proper way, AFAIK, is to use the same target curve for all speaker groups.
That's something that's also not my experience. The auto-curve that's applied is fine (which AFAIK should look like the one that's flat at bass and -2.5dB in the treble I believe), except that many will find a flat curve too bass shy. In the manual, it tells you to apply a 6dB boost in the bass if that's the case. I think the bass boost should be standard, since the vast majority will prefer it, but otherwise don't see the issue.
Why would you want to adjust the delays? And if you're talking about the subwoofer crossover, Dirac doesn't have any control over that unless you're using DLBC. For the "regular" Dirac, the AVR (or other device) is handling the bass management and you have to adjust it there.
If you're referring to loudness compensation here, then sure that'd be a great feature. On the other hand, Audyssey's dynamic EQ is largely unusable IMO because of the distracting boost to the surround channels when it's engaged.
That is the target for surrounds. The plots I posted are the default targets Dirac came up with no additional adjustments from me.
It really depends what is the reference (dialogue) volume you listen to. For instance, the equal loudness curve for 60db and 2db drop from 20Hz to 20000Hz has a +14db at 20Hz and it drops to negative db at mid freq per the first post. For 65db, it's +11db at 20 Hz, and so on. So, I would guess that the 6db boost works when you listen closer to 85db. Plus, the db boost doesn't mimic the shape of the equal loudness curves anyway.
Dirac (regular) sets the delay for the sub. I can see the delay on my AVR, but I can't adjust it. Adjusting that delay is another way to smooth out the crossover region between sub and fronts.
Every time I upload a new tune, the crossovers are reset to 70Hz for all speakers. The LFE crossover is set to 120Hz. In my previous post I was refering to the 70Hz crossovers.
I'm not asking Dirac to implement DEQ. Just asking to take the equal loudness curves into account. I didn't realize that Auddisey DEQ was distracting on the surrounds (when I was using Denon, my surrounds were not properly setup anyway, long story). Anyway, that may be the reason why Dirac doesn't boost the surrounds. But then, more reason to apply something like the equal loudness curves on the Dirac default tune.
Another thing I noticed with the default tune was that my surrounds were anemic. I was watching a scene where the voice was coming from the surrounds (the space ship computer was talking) and I could barely hear it. I had to increase the gain on the surrounds. When I switched to the curves posted in the first post, that was not a problem.
I have extended range of targets, for those, who want to listen really quietly. It goes down to -50dB below reference, but I'm not sure if Dirac can make that much of boost at low frequency.
As previously: target-35dB.txt is for listening at -35dB below reference and is equivalent to target-r85-s50-h0.txt, target-45dB.txt would be equivalent to target-r85-s40-h0.txt
Thank you for these curves, I am actually curious how you did the calculation. I would like to add loudness compensation to the Storm Audio Dirac curves and I do not know how to create a curve withe the applied loudness changes. How did you create these targets? Within a spreadsheet or a specific formula?
I have used formula from ISO 226, you can find it in internet.
If you have an Excel that you could share, it would prove invaluable for people that are using custom curves, for whatever reason.
I have written a quick and dirty script in awk. Let me know if you are interested, then I will clean it a bit and post here.
I think it could be interesting, sure. Not familiar with awk, though.
That would be great! Unfortunately I do not have knowledge of AWK scripting as well, although I see that it is possible to install on windows systems as well. (Or I can make virtual machine to run the script as well)
I don't have much knowledge of AWK either ;)
I attach scripts here. I hope you can understand them. Batch is for Windows command line.
Tried executing the batch file to get a feel for what it does. It generated a huge list of files, with adjustments for different scenarios.
If I understand things correctly, there's the reference level to which the original curve is targeted for and then the script proceeds to adapt it for different listening levels. What I don't understand is where the curve you're using (I suppose some sort of Harman, with different levels of bass, the "h" portion of filenames generated) comes from. Is it hard coded in the awk file, procedurally?
Function start2023() initiate table of coefficients according to ISO 226.
Function fun_Lf() calculate equal loudness curve according to formula from ISO 226.
Function home_cur() calculate something like Harman target curve.
Functions target() and target_diff() use fun_Lf() and home_cur() to draw target for Dirac. Target is a sum of loudness correction and Harman curve.
