Honestly I cannot remember why I done it
So I have come up with these three setups so far
https://addictedtoaudio.com.au/products/topping-b200-pure-power-amplifier + https://www.minidsp.com/products/minidsp-in-a-box/flex
This is straight to top end, very little above this even then it's splitting hairs , but looking at 3k+ , the amps are AB vs D for everything else and fall perfectly in 86 db sensitivity, but D class has come along way in the years where most people can't even tell the difference between, a, ab and they do 8ohm at 200w and have a high low gain , I'm really leaning this way
- https://www.amazon.com.au/Fosi-Audio-ZA3-Amplifier-Floorstanding/dp/B0CLP4T5L7 + https://www.minidsp.com/products/minidsp-in-a-box/flex
Cheap, but packs a punch well above its weight, review are OK looking at ~1500, class d , number of reviews of these dying, company replacing the, cost is low, ~250 off amazon 100w at 8 ohm
- https://www.minidsp.com/products/streaming-hd-series/shd-power
All in one unit, around ~2500 reviews are around the same as the ZA3, has a power amp built in 130 w at 8 ohm, less cables, less boxes mid ground easy if I go 1 or 2, given the DSP is external to the AMP I can upgrade amp at any time if I wish, if I go 3, single unit, need to go back to split or find a better single
