Or heavy duty tube amps that only put out 75WSensitivity of 87 and max 150W? thought most owners of 20K speakers also own heavy duty amplifiers.
Sorry, my response seems to address me myself more. No, I'm a DIYer who questioned a lot of his evil deeds already.Thanks for the response.
Really? I'd say the percentage of audiophiles who listen to classical music ....
Sorry, my response seems to be targeted at myself more. No, I'm a DIYer who questioned a lot of his evil deeds already.
Topic: why 2.5-way? (a) baffle step compensation and (b) having two basses for more power, while only one of them does the mids as to ease the x/o design, avoiding a midrange driver, doubling parts in the x/o, and foremost quadrupled complexity.
Problem, as I see it: since both drivers are designed for and will undergo higher excursions of the cone, a certain sort of non-linear distortion is generated. The intermodulation of mids with bass tones. That's a typical annoying gargling to shrill sound, once known, will be easily detectable in tiny portions.
Even with the best motor designs such IM cannot be avoided. They are also generated independently by other mechanical properties. Most prominent is the resonance of the surrouns/suspension of the cone. Around that frequency the IM may reach like 10..30% even with, by todays standards, morderate excursion. In short I would say that a driver which is used for mids also must not move by more than, say +/-3mm. I personally find 1% of IM is a natural limit for high q/ audio. My personally most sensitive freq/ range for detecting IM is from about 300Hz up to 2kHz or so. ( The range of human voice ... ).
But You might have seen the compromise here: would You use one bass and drive it hard, whilst the mids are taken by a dedicated driver, not loaded with bass, hence no IM to speak of. Or would You trust a double team of basses, that will consequently not be stressed that much, so that IM is kept in check, even if one of them gives the mids also?
I came to design real three-way even for mini-boxes. Bass is contaminated with IM once in a while. But not as much, since the region of the surround resonance is avoided by design. The mids are utterly clear again by design. I like it, subjectively.
DIY gives me the opportunity to explore things like that, mind You.
One anecdote to close the case: when the BBC introduced the plastic cone, which made the larger two-way feasible, it wasn't perfect. The surround of the referring drivers had do be dampend heavily as to support the no-resoance approach. The worst originator of IM was by this avoided unknowingly. Only later the surround had be be 'loss less' for some mythical reasons, which became possible with improved plastic material for the cone. And down it went ... . Old SEAS drivers are infamous for their 'lame' sound, yep, IM is missing, the speaker has no 'voice'. I want to listen to my 'signature' speaker
The best definition of an Engineer I’ve heard is:I regret that 80% of the comments here are about the price because there is a moment when you have to say if it's a bad design or a good one, ignoring the price and I don't think it's really the case because with a bit of EQ correction they become almost SOTA speakers, especially since in Europe these speakers are sold at 14K usd which is already a nice sum but more "digestible" than 20K
although in this range of "standing" and of concept of small domestic columns compatible waf I will direct myself towards the Magico A3....
I take my hat off to the TAD team for having lent a copy for measurements on a forum of ayatollahs of SINAD and Spinorama!
Seiko makes some of the nicest watches in the world. This one is $11,600. I think it’s the same mentality with high end watches and audio. Maybe ego or just an appreciation for something that is meticulously crafted and a big wallet of course. I can’t say that I find the price of these TADs to be that shocking. It’s those little thing like the binding posts that Amir mentions that make them just a bit better and if you have the coin go for it. Here’s the rub though. This Seiko measures better than many Rolex models. This speaker measures very good, but looks to me like it should be a bit better. And if I was seeking perfection I’d be a little bummed by it.My Seiko watch keeps perfect time, why do people pay thousands on a Rolex? It’s all about image.
Yyy, yes, of course? If not good engineering, what kind? Bad?We should expect good engineering at $100K?
I like it, but unfortunately a finished product is not just about engineeringThe best definition of an Engineer I’ve heard is:
He will look at something that cost a dollar to make, then go and make a better one for 50 cents.
Could have bought about 120 of mine for the price of the one in your post. Getting back to the TAD speaker review for $20k would have expected something better visually. Paid £650 for my Kudos X2s Ex Demo, fit and finish is immaculate plus they sound terrific in my 16’ 6” x 14’6” living room.Seiko makes some of the nicest watches in the world. This one is $11,600. I think it’s the same mentality with high end watches and audio. Maybe ego or just an appreciation for something that is meticulously crafted and a big wallet of course. I can’t say that I find the price of these TADs to be that shocking. It’s those little thing like the binding posts that Amir mentions that make them just a bit better and if you have the coin go for it. Here’s the rub though. This Seiko measures better than many Rolex models. This speaker measures very good, but looks to me like it should be a bit better. And if I was seeking perfection I’d be a little bummed by it.
Agreed but all design and it’s implementation are governed by cost and you’re right cosmetics sell a product for a limited time span. Years ago went for an interview as a designer of electrical accessories. They had an array of their products on a bench one of them was a connection clamp to fit on an earth rod. It was well made and complicated, if you were into this sort of thing certainly beautiful. He asked for my comments and told him it wouldn’t sell. The existing widely used design was a simple U clamp, cheap cheerful and did the job. He wasn’t too happy and the interview went downhill, still if he couldn’t see cost mattered his business was doomed. The parent company closed it down a couple of years later.I like it, but unfortunately a finished product is not just about engineering
Need to complete it with something like "and the marketing/sales department will sell it for more"
Something virtually every ASR member ignores (or is unaware of) and complains about in every product review post that includes price is that in some products (things that are not commodity items especially) there is no relationship between price and cost. Let the whining begin
It's not about "whining" it's actually laughing at you because you seem to think because it's expensive it's "better".Spare us any more of the faux "financial envy" syndrome yer spouting.Im sure you have some knobs to polishI like it, but unfortunately a finished product is not just about engineering
What i meant is: is 20k not enough to expect good engineering?Yyy, yes, of course? If not good engineering, what kind? Bad?
Ironically the Kudos speakers tend to measure “poorly” as well. They take a design by ear approach and it shows up in some wonky measurements, especially peaks in the highs.Could have bought about 120 of mine for the price of the one in your post. Getting back to the TAD speaker review for $20k would have expected something better visually. Paid £650 for my Kudos X2s Ex Demo, fit and finish is immaculate plus they sound terrific in my 16’ 6” x 14’6” living room.
