Hi everyone,
I am in the phase uf opgrade my audio system and I need a bit of advice and opinion on possible/suitable equipment
My current equipment consists in:
Panasonic DP-UB9000 UHD
Naim ND5XD2
Sansui AU-919
Dynaudio Excite X38
Marantz SR5014
B&W DB4S subwoofer
Other speakers to create the 7.1 sorround system
The connections are done as shown in the picture below
I would like to replace the Sansui as it is under a lot of stress as it is used as power amplifier and it is under a lot of stress with the Dynaudio;
My focus is on the hifi/stereo quality rather than home theater, and for this reason I would like to replace the Sansui only.
I have a test (of course) to evaluate equipment that may fit in my layout. My preferred local dealer trade Atoll, Musical fidelity, Moon, Mcintosh and a few other brands that are in the hifi market, but he does not have Accuphase, Luxman, Hegel.
Tomorrow I have a test and I will try
Atoll IN200SE
Atoll IN300
Moon 240i
What other brands do you advice me to look at?
Or would you rather separate at 100% the hifi from home theater and therefore get a pozer amplifier (ie Atoll AM200 either as stero amplifier or dual mono) and get some other speakers for the home theater?
Thank you very much for your advice/help/support
Antonio
Naim ND5XD2
Sansui AU-919
Dynaudio Excite X38
Marantz SR5014
B&W DB4S subwoofer
Atoll IN200SE
Atoll IN300
Moon 240i
Antonio
