Sylph Audio FB100 Stereo Amplifier Kit Review
Rate this amplifier kit:
    Votes: 0 0.0%
    Votes: 6 5.2%
    Votes: 35 30.4%
    Votes: 74 64.3%
The FB100 requires a differential (balanced) input. Because of this, it might not be directly compatible with your setup without using an unbalanced-to-balanced converter.
Can it not use a SE-to-balanced adapter cable like so many people here use between a SE source and amplifier with balanced inputs?
Cable can go balanced to single ended, it just throw away one phase.
Cable can not go single ended to balanced - it can not create extra inverted phase.
Some, but not all, balanced inputs require equal magnitude inverted phase. I am currently happily using a form of this:
Reactions: EJ3
In that situation I will call it single ended input, with XLR plug. It is not differential or balanced.
Probably the balanced input is needed to drive two half of bridged tied load (BTL) output.
