Every speaker is a set of compromises. That's a technical fact. For some, large dimensions and high cost are a deal-breaker. Others might want to reduce reflections off the back wall using a cardioid speaker to avoid the dip in the upper bass/lower midrange that omnidirectional speakers exhibit. Yet other people may want to listen from relatively close distance and value the coax design with woofer on the same height resulting in one of the best approximations of a point source on the market. Some just want a fullrange speaker that easily supports unlimited 96dB SPL listening in actual rooms. Or they want to add subs and play up to 106dB without limitations above 70Hz from the Orbits. And then there may be people that love the orange ring
. Plenty of good (technical) reasons to choose the Orbits over the KH420.
It seems to me, that emotions are the only plausible reason behind your continuing efforts to discredit the highly sensible set of compromises made in the design of the Orbits. Your technical reasoning doesn't convince me at all. And while I can understand people who point out even the smallest design flaws in expensive speakers (looking forward to comparing the 10k€ D&D 6C with the Orbits), I don't quite understand the mindset behind the same behavior when it comes to a very affordable product. That's why I questioned your motivation.
The kind of performance you are demanding requires specific technical solutions. Simple solution is big size. Obviously the subs tested in your link are more about small size. There may be good reasons for that.
Laws of physics is a typical excuse for poor engineering. It's possible to include a feedback loop or forward correction in small woofers to reduce distortion drastically. Still, there are not many product designers or companies interested in such technical solutions. Part of the reasons for that is the low return in audible improvements on the invest of engineering effort. People that have the opportunity to listen to a woofer with distortion reduction switched on/off instantly, may realize that low-frequency distortion is not such a big deal as THD measurements suggest and can even be preferred over more sterile sound without harmonics.
If you don't accept trade-offs - fine. Don't know if you’re are a cost-no-object guy or don't care about size or simply ask for a feature set you will never get. Maybe you even built your own speakers/subs integrated as furniture or the like. In any case, others can have different views on things. Maybe you could focus on products that suit you better and allow for constructive contribution from your side?
If you had a look at my posts about all gear I have commented you would see that I never consider cost, cheap or not.
What concerns me are fatal flaws first, safety, etc.
About flaws now:
The long ASR tradition about ALL gear, is noise.
That's what makes champions, either DAC, amps, etc, abysmally low noise, far from human detection.
Why? Cause it's the one flaw anyone hears when it's skyrocketed. What good are any gear when they make themselves evident with no signal?
Then, is ability. Either extension, SPL, etc.
When looking at a speaker's THD and H3 competes with H2 early, that's its limit. H3 down low is about excursion and its limits.
Packing all the DSP you can pack and stack and push a speaker lower than it should and you'll have Amir hear it complaining, you'll have others talking about one-note bass, etc.
There's packed design, where one tries to include properties that will show nice to a potential buyer on paper but will be unusable in practice (or unintened use) and there's honest and smart design (like Sigberg for example, who makes speakers specially for used with subs without compromising their extension vs SPL) or, or...
Sure, people want it all if possible.It doesn't mean that is also doable within constrains.
Anything goes out there, and at a technical forum, we, the members prefer to talk about this kind of performance instead of anecdotes and personal use cases.
(as far as I know, commenting and posting is still free for non-buyers of any gear at ASR, let me know if that has changed)
