Notwithstanding it's undoubtedly poor measurements I have no problem believing that, (ahem) subjectively, that amp sounds better than almost any SS, but it's pretty onerous having main components that are service replacement items and are in danger of expiring prematurely if ambient temperatures go over 30°C!
That one's been trouble-free for 20 years with the exception of one 6SN7 (a used
plinker of unknown provenance that I was using in it at the time) driver tube that self-immolated and one of the output tubes' bypass capacitors, which failed due to prolonged exposure to too much heat from being placed too close to the resistor. Those monster brown caps (in the photo above) solved
that problem.
Actually vacuum tube hardware is far more robust,
albeit at the cost of electrical efficiency (which can be mitigated in a push-pull output design
, of course).
Best of all, all of the components in that amp are readily available and have been for decades. Actually the James OPTs in it are no longer made, but there are plenty of other options for replacement OPTs if ever needed. The power output triode (2A3, in this case) was introduced by RCA in 1933 and has, as far as I can tell, been in continuous production somewhere in the world ever since.
EDIT: Yes it sounds great -- and it measures
OK, all things considered. It
is a 3 watt per channel amplifier, after all.
But it will put out its full three watts (at about1% THD) across its bandwidth all day and all night without any fuss -- which is apparently something the Class D modules cannot and apparently weren't designed to do. So there is that.
