ThanksThose are all MicroAudio. I’ve had success with Connex and Mean Well, too, but would choose MicroAudio first.
"signal", not "sign".If the switch mode supply delivers the same DC voltages as the conventional supply does, it should make no difference. Only possible problem could arise with the SMPS is that it is likely to be regulated, and won't sag much under load, whereas the 50/60Hz-xfmr-diode-'lytic one will sag, limiting the power dissipation in the output stage when severely overloaded. So long as that overload/dissipation issue is properly addressed, then both types of supply should work well. Power amplifier output stages don't benefit much from regulation, while small sign stages do.
By the way, is it not a problem the constant current of CLASS AB with these SMPS?Those are all MicroAudio. I’ve had success with Connex and Mean Well, too, but would choose MicroAudio first.
It's fine as long as the new power supply is capable of the same (or higher) current.By the way, is it not a problem the constant current of CLASS AB with these SMPS?
I have found the term "linear power supply" rather strange for the traditional format - but language/society/linguistics often follows fashions and mythologies rather than straight logic.... so I comply with the term rather than swim against the current...Glad I ran into this, glad someone did a measured comparison. Back when I was DIYdesigning amps some years back, I used SMPS supplies and could find no negatives at all with that. It always makes me shake my head when I read someone talking about and praising old 50/60Hz transformer, rectifier, and bigass capacitors as "linear supplies". There is absolutely nothing about those that is "linear", just antiquated. Changing AC power into DC is about as nonlinear as it gets, and having line frequency related residual in the audio band is way worse than at supersonic frequecies in every imaginable way
Hi, I'm no expert, so could you elaborate on this a little?I think it comes from mystical dislike for the idea of switching. As if switching at 10s of times per second, then trying to clean up all the junk is somehow better than at 100s of kHz. Probably many don't realize that a tradional rectifer arrangement is switching also, and in a pretty bad way..
2x4700uF per rail. The filter board is described in the SMPS500Rxe pdf guide and can be ordered/customized from the connex shop.How much capacitance per rail?
No.Did you measure ability
I followed the setup guide as part of the DH-220C package from Bob Cordell. I do not recall the exact figure, but I believe it was ~200mA per output FET. See the 2-part article in AudioXpress.what is the idle
HF garbage from the fast rise & fall times of waveforms in switch mode supplies, which switch at high frequencies, is difficult to clean up, since it sprays everywhere like RF. That's not such a big problem in 50/60Hz supplies, especially when soft recovery diodes are used.I think it comes from mystical dislike for the idea of switching. As if switching at 10s of times per second, then trying to clean up all the junk is somehow better than at 100s of kHz. Probably many don't realize that a tradional rectifer arrangement is switching also, and in a pretty bad way..
Yes, but at which frequency this HF noise spread? Above the switching, so very high.HF garbage from the fast rise & fall times of waveforms in switch mode supplies, which switch at high frequencies, is difficult to clean up, since it sprays everywhere like RF. That's not such a big problem in 50/60Hz supplies, especially when soft recovery diodes are used.
Different switch mode supplies may use different switching frequencies. The sharp edges of the switching waveform generate a spectrum of noise frequencies. I agree that these frequencies are vastly higher than humans can hear, but they could cause misbehavior in amplifiers, especially those that use negative feedback, which the majority of them do.Yes, but at which frequency this HF noise spread? Above the switching, so very high.
Diodes switching noise start at lower frequency,
