set the smoothing to no smoothing or 1/48 smoothing for bass and set the limits dB vertically to 50dB difference. Basically it should be 50 t 100 on the vertical scale not 25 to 105Hi all, new here
I have the SB17 Svs sub, used the rew to measure my sub.
My living room has no special treatment in it.
Got the following results:
Any suggestions what can be done using the svs app. If at all?!
Thanks
only then can we make good deductions from your measurement
pretty good for one sub tbh. you might have remarkable barebones acoustics. the real issue is the 40Hz dip which is nota narrow dip. we care less about the other vagaries. I am jealous lol
View attachment 480869My living room has no special treatment in it.
That us not a good idea if the aim is to knock down peaks in the bass region. Then use no smoothing or Var smoothing to get the correct width (Q-value) of the PEQ filters.If you decide to do some DSP correction base it off of Psychoacoustic smoothing and you will avoid over correcting which sounds worse that leaving well enough alone.
We can agree to disagree. I have tried it several different ways and have better results (my preference) using Psychoacoustic smoothing. This is most likely because the Q values are much lower and you use fewer filters as well. All filters, and high Q filters especially, cause phase and timing issues and in general are suboptimal. The human brain does not hear the same as a microphone and has abilities to "hear through" the room so you don't have to hammer the response perfectly flat to get good sound. I alway try Var smoothing and Psychoacoustic smoothing before generating corrections and almost always prefer the Psychoacoustic smoothed filters. YMMV.That us not a good idea if the aim is to knock down peaks in the bass region. Then use no smoothing or Var smoothing to get the correct width (Q-value) of the PEQ filters.
Ok, I agree to disagreeWe can agree to disagree. I have tried it several different ways and have better results (my preference) using Psychoacoustic smoothing. This is most likely because the Q values are much lower and you use fewer filters as well. All filters, and high Q filters especially, cause phase and timing issues and in general are suboptimal. The human brain does not hear the same as a microphone and has abilities to "hear through" the room so you don't have to hammer the response perfectly flat to get good sound. I alway try Var smoothing and Psychoacoustic smoothing before generating corrections and almost always prefer the Psychoacoustic smoothed filters. YMMV.
OK, but if we are going the "appeal to authority" route @j_j recommends "ERB smoothing" (which is very similar to Psychoacoustic smoothing) before adding a correctionOk, I agree to disagreeI’m talking about the one PEQ filter that would knock down the peak of one resonance. Since this is a minimum phase phenomenon it will be inverted by a single PEQ - provided the Q is correct, of course. Floyd Toole gives a nice account of the situation in Sound Reproduction, Section 8.2.4 in the 3rd edition. And see Figure 8.12 for how the impulse response is affected.
Guilty as charged! But appealing to authority isn’t necessarily a bad thing. Floyd Toole and JJ usually brings value to a discussion. As a general comment I would say that there is too little use of references and links in discussions here at ASR.OK, but if we are going the "appeal to authority" route …
Are you sure @j_j was talking about corrections below the Schroeder frequency? I’m talking about isolated peaks in the frequency response coming from an excitation of a room mode. If I’m missing something, I’d like to know.… @j_j recommends "ERB smoothing" (which is very similar to Psychoacoustic smoothing) before adding a correction![]()
I got this from a post on ASR and saved it, I can't find the post right now but I think the .ppt mentioned is around.Guilty as charged! But appealing to authority isn’t necessarily a bad thing. Floyd Toole and JJ usually brings value to a discussion. As a general comment I would say that there is too little use of references and links in discussions here at ASR.
OK, but if we are going the "appeal to authority" route @j_j recommends "ERB smoothing" (which is very similar to Psychoacoustic smoothing) before adding a correction![]()
I would recommend trying both and listening to see which you prefer.
Seeing my rew result on the low frequencies, would you recommend changing anything using the subs eq or do nothing at all?To some extent you're talking about two different things, I suspect. Are these peaks (not at under 300Hz or so) due to loudspeaker? Fixing a loudspeaker that way isn't necessarily a bad thing, but fixing a room that way, because room reflections do that, is maybe a very bad idea, because you're going to shrink the listening area in the room to a space smaller than your head.
Some clarification may be in order.
