- Joined
- May 31, 2020
- Messages
- 1,064
- Likes
- 1,960
What a rip off that they do not enable autoeq on 2000 pro and 3000 series. Computing power is nonsense, they just wanna sell new subwoofers.
Suggest you migrate to Anthem gear.Would never rely on their app for sub EQ and management. Unless you have something to work with your other speakers, this is not going to be a wholesome solution. We had DSPs on subs for a while now and could manage that with REW quite easily - subject to the first point above.
SVS for one does not have distance adjustment in the older subs like PC 4000 that I have. A bit of a bummer as phase adjustment is not quite the same as the distance adjustment. Could be close in that low range, but not the same. To that extend Arendal did better as they have both.
My recommendation - get your bass management and EQ sorted out outside of this solution. Always good to have more tools but we should understand their limitations.
The signal is going through a AD/DA stage that is not really good, I had noise issues.Can you elaborate?
I am already on Dirac ART, which not only does phase alignment but also, unlike most other solutions, reduces decay up to 150hz. It is also quite easy to set up and even auto setup produces great results. Not perfect, but probably best auto EQ system for low end.Suggest you migrate to Anthem gear.Their Auto Phase Alignment works great as a final conclusion of an ARC run. You run it after the room sweep. I do 7.2.4
Easy peasy.....
I’d personally go on their website and start a chat. They’ve always been very responsive with misc questions I’ve had.Can anyone specify the DSP latency in the new Revolution series? I know that in my 2000 Pros it is 6 ms. Is it lower in the new line-up?
