gks333
- Joined
- Dec 1, 2021
- Messages
- 44
- Likes
- 40
SVS PB-3000 vs JTR Captivator RS1
Researching and getting data now for possible future upgrade.
I currently have 3 SVS PB-3000’s and one SVS PC-13 ultra (800w amp). My theater is in a real world environment that is approx. 7400 cu-ft open via hallway to the other 2/3rds of the house.
I have had Rythmik FV15HP set up next to the PB-3000 and it was just a hair too large to give you all an idea of acceptable limits. PC-13 although large and unsightly goes unseen behind TV.
Currently I am Mostly satisfied with the subs. I have tuned all 4 subs to work together and work with other 5 speakers (revel F208, C208 and S206) via REW. This is a 99% movies setup. WAF is a factor thus captivator RS1 and not Captivator 2400. When playing demos at MY ref levels (maybe 3 clicks louder the normal movie viewing levels), subs are probably near 95% of controlled max output (max being level observed via compression tests). I would like a bit more headroom, a tad more low end extension (14ish hz) and a bit more mid bass (think John Wick). My concern is that 3 RS1's (if paired with PC-13ultra) or 4 Cap RS1’s will not equal or may only be marginally better for my desires and application compared to current setup due to ported vs sealed subs used for movies.
Below are my last REW sweeps and in room response currently at MLP (main listening position) which is 122” (ears) from TV. Room specs are Width 23’ 7”, length 35’ 8”, Height 8’ - 10’ 5” at vault ceiling peak. (approx. 7400 cu-ft) OPEN to the other 2/3rds of house via hallway.
Below, ALL subs AND all 5 speakers.
So, in all honesty, would it be worth it in regards to bass output/quality to reduce hypothesized headroom from 95% to say 55%ish and achieve usable 14ish or less hz? Please state if you have had ACTUAL experience with these subs or damn near similar and not just looking at specs and assuming/hypothesizing.
Thanks.
REW -8db
New miniDSP settings
PEQ1 52hz -2db 3Q
PEQ2 33hz 2db 3Q
PEQ3 41hz 3db 1Q
Only center sub inverted. Only RR sub delay of 3
Xover 17hz BW 48db 88hz LR 48db
Full sweep. 79-93db, 14db extreme spread.
PEQ1 52hz -2db 3Q
PEQ2 33hz 2db 3Q
PEQ3 41hz 3db 1Q
All sub sweep. 9db extreme spread. Really low around 34 and 85hz.
Just subs, compression test. Started at -14 vol and next was -9. Reason for that large spacing. Increase of 3 vol on AVM60 between sweeps.
Thanks.
