Svs or ….
Hifi for life .
Wiim Ultra pre streamer combined with the Vibelink power amp designed by Wiim.
Is it better to buy the
SVS SB-1000 Classic.​
Wiim setup has a powerful DSP engine .
SB1000-PRO can be beneficial to see if I would need to adjust the parametric EQ functions.
As mentioned Wiim has this …
But in corner it might be necessary to use SVs build DSP and EQ .
However even if the Yamaha AS701 would be full range the loudness (volume ) is way louder then Vibelink .
I know the input sensitivity and the design of volume control is different between this manufacturers.
Thanks for reading . Speakers are Evoke 20.
Mogami and Van Damme cables
may as well get the classic, run no eq or anything on it, and let the wiim handle the crossover, level matching, eq etc etc
What is meant by "However even if the Yamaha AS701 would be full range the loudness (volume ) is way louder then Vibelink ."
They are both 100W into 8 ohm amps and while the price is similar (Ultra + Vibelink vs. Yamaha), the Wiim is a DAC streamer.
Either unit can be made to work well with any powered sub.
Expensive cables are a waste of money unless you like the prettiness of them.
If you are asking what to buy, for me the Wiim is a no-brainer.
If it's about which sub to buy, I'm sure they are both more than good enough, but why limit to SVS only?
I'd always buy two subs.
My SB 1000 pro has room correction, so three pre set roll off options (40, 31 or 25hz, at 6 or 12dB slope), and 3 DSP settings. The DSP is limited, in that dB is only in whole numbers, and the Q factor seems to be about 1/2 of what Wiim does (so a Q=5 on Wiim is about a Q=10 on SVS). Oh, and +6 boost max, -12 cut max. So it does take some attention to detail to integrate, mostly actually looking at the curves on the SVS and Wiim to make sure they line up correctly.
Given my room and my 100 year old floor, those 4 extra settings were worth it. If you don't need them, don't pay for them is my rec.
There are other options, but SVS is a solid choice for a sealed sub.
I have a Wiim Amp Ultra driving my ESL-63s with an SVS 3000 Micro sub. I just use the LFE input on the sub and let the WAU handle the crossover function. The WAU uses a 4th order crossover. It all sounds pretty good to me.
You use a Wiim with the SVs sub ?
I mean depending on the input sensitivity/gain on volume control. Each amp might differ …
Yamaha AS701 barely needs to be on 9 o clock before it cracks up the bass .
Wiim volume control is linear design, hence it needs more steps to sound decently loud.
I’ll probably need to get used to it .
I own the AS701 Node N132 , Ultra Wiim streamer and its companion the Vibelink power amp .
Yep. I use the sub settings first, then layer on the Wiim corrections. I cross at 80, so I keep the SVS corrections under 40hz, which keeps things easier. Which is not a problem given my situation, there's a lot going on down there.
The only thing which bugs me is the Vibelink has lower input sensitive gain. Meaning the volum dial needs to be on 30-40.
And on 50 the volum is more than enough . Still it is not as powerful like the AS701. This could change by adding 1 sub to the Wiim Ultra pre streamer.
I know modern liner volume dials needs more gain to get really loud. Old potmeter doesn’t need lot to sound loud.
I think the dsp in the SB1000pro is a very handy tool. I use the room gain roll off which WiiM RoomFit doesn't fix as good.
As for the 701 louder than the Vibelink. Yes, input sensitivity x10 gives that impression. Reduce WiiM Ultra output to 200mv to retain the full volume knob function. The Vibelink connected via optical and using it's ESS9039 is far superior to the Yamaha IMO.
It is to 2 rVMS. The highest spec number.
My bad the volume dial is set to 100 inside of the app but the Vibelink power amp was set to 9 o clock. 9 o clock is too low in loudness .
Viblink /Ultra pre streamer is a killer setup for such speakers like R5 (old version) and the new Meta. Of course Dynaudio too.
I do get the impression many audiophiles scoff at Wiim. “ you’d think they’d have the sence to buy the Hegel H190 V2 with the speakers above “
I hear them arguing about this.
Yes, Wiim might be too “neutral “ ; but if you it buy the Umik-1 and measure the listing room using REW. Wiim own Rom Fit which provides probably 60-70 percentage performance below Dirac etc. You’ve then managed to get a cracking HiFi system well below the the likes of Primare, Arcam etc,
Considering either the DSP-SVS sub (1000 PRO) or the Classic. 2 in mono crossing at 80 Hz well probably sound awesome with the Evoke 20.
If you have good sub integration in further upstream devices I find the "helpful" sub apps to be a big negative as they add delay (which needs to be corrected by delaying the mains) and in general I find myself fighting a black box of DSP during the integration process. Much better to use one good integrated DSP system than spreading it out over multiple devices which often leads to unexpected and hard to understand issues.
