Is that grill removable? Asthetics looks terrible, it would look better with the inverted woofers bare. It looks like Joe N' Tell removed his but he didn't explain how and he made it sound like it wasn't a good idea.
Friction fit. Just used a sharp pair of tweezers to fit into the grill holes and pulled up lightly on different sections making sure not to poke the driver.Is that grill removable? Asthetics looks terrible, it would look better with the inverted woofers bare. It looks like Joe N' Tell removed his but he didn't explain how and he made it sound like it wasn't a good idea.
I think it was actually pretty precise. It seemed to have some kind of felt or something. It definitely required some force which tells me it wouldn't be likely to vibrate or be taken off by kids. I think they also wanted to keep it as compact as possible as grills add width.Hmmm - that doesn’t sound good. To me the sub also looks better without grills. For this price i expect something better than friction fit...
I think grills removed is the way to go....unless you have young kids.No worries - you were very precise. I’m surprised that SVS did not use a magnetic fixture or something which is easier te remove. In any case: _if_ i buy the 3000 micro the grills will be removed.. much nicer that way.
The specific stiffness (modulus/density) of aluminum alloy and steel is actually pretty similar due to the difference in density between the two alloys.
Correct, my mistake, I didn't mean specific I meant simple stiffness. I have been pointing that out for 40 years
.Actually porosity just reduces the section and therefore increases strees, particularly locally. Mind you if a measurement was made of a porous sample the modulus would appear to have changed if the cross sectional area was not corrected for the area of the voids.castings also typically have poor fatigue and strength performance compared to wrought. I would imagine not a huge difference youngs modulus for a given alloy composition (the porosity in the casting may effectively decrease the modulus).
SVS has very nice build quality, at least on my PB16. The friction fit of the grill I use is excellent. Everything lines up and it stays put.Hmmm - that doesn’t sound good. To me the sub also looks better without grills. For this price i expect something better than friction fit...
Or a dog. Which is why my PB16 has the grill on.I think grills removed is the way to go....unless you have young kids.
I think Seaton Submersive is another example.Rhythmik, GoldenEar, Dynaudio, Bowers & Wilkins and Barefoot are among the companies currently offering dual opposed subwoofer models.
for a given cross section
Could be. You were convincedAre you honestly asserting that manufacturers** who use cast baskets are specifying an inferior item that's harder to make and more costly.
making a linear long travel motor is the clever and important thing
There is this dual driver micro sub: https://community.savant.com/Defaul...isCSRFlow=true&portalUser=&store=&cclcl=en_US
It is only 7.5” x 8” x 9”
What I find surprising is the lack of weight, only 22.5lbs. Wouldn't a good motor need much beefier magnets ?
In contrast, the KC62 is 30lbs even though it's physically smaller.
Sounds like, IIRC, Tyrrell's pursuit of a carbon-fiber transmission housing. Expensive & difficult to engineer, but it would allow you to relocate ~10-20kg ballast, because your car was already under the mass limit!My boss insisted we should be getting them, even though our budget was limited and we had shown on a test rig they were definitely not better.
