Welp - The pair of 3000 Micro R|Evolution's were nice - but not quite enough SPL in that 20-40Hz region I really need the support in. They will do the trick in the upper bass - but I don't run them that high, and I need the last octave to "be there" at more moderate levels. The Micro's come into power compression pretty quickly as expected in the deep lows - so I don't feel I'm getting much more than I was before from the "27Hz" Dynaudio subs (if anything, the Dyn's matched SPL at 20Hz - well below their tuning - and smoked the Micros' at 27Hz of course - but still only 4x 9" drivers with limited xmax - just the very large enclosures and being ported does a lot here with 9" drivers).
The DSP is pretty heavy-handed to get that 20Hz response from sealed 9" drivers - you can hear it sometimes (likely a combo of the DSP and driver non-linearities) - and makes them localizable in some instances (being pushed in the last octave).
But at moderate levels - they did sound great. Just not enough SPL to keep up with the SPL capabilities of the KH-150's in the last octave. I knew it was going to be close based off the published 30Hz specs and Erin's testing - and it just wasn't enough for me in my room with my SPL desires coming from the Dyn's.
The cabinet is SERIOUSLY impressive and totally inert. Even at full-tilt - the cabinet has zero resonance - and the opposing drivers completely null any inertia. It's almost unbelievable.
That said - a 15" sealed SVS SB5000 is on the way Thursday!
Almost did the SB17, but just a hair too large of a footprint for the main sub position, and none of the ported "PB" models are an ideal footprint in my room (too deep). The SB5000 is still MUCH smaller than the Dyn subs I was running before (mainly speaking of their massive height, and one vs two) - and I might be able to squeeze an SB3000 in the second sub location if I make a few small compromises (main design goal - not to have to make compromises with Mains setup to accommodate new Sub placement).
So I'll see how the SB5000 does in the "proper" main sub position (the Dyn's would not fit there), and go from there. I was pondering trying the two 3000 Micro's as Nearfield Subs on each side of the MLP and trying to use them more as ART Support for my major 40Hz constructive room mode (where the Micro's have moderate output at 40Hz) - but I think a "full size" SB3000 in the second position on the front wall would be a better and more matched option. I'd imagine some very funky response trying to run the two 3000 Micros with the SB5000 and power compression from the Micros making higher SPL's non-linear and wonky...
Anywhoo - If you like low bass SPL - the 3000 Micro R|Evolution is a bit shy IMO. Upper bass will impress all day long, and at low SPL the subs are delicious. I'd say a PB1000 is the cheaper better option if the size works and you want good 25Hz response. If you MUST have an expensive tiny sub and don't need >100dB SPL in the low-lows, the 3000 Micro R is very nice and looks fantastic...
Toodles
