Survey: Is your mains-powered gear mostly 2-prong or mostly 3-prong?
Is the majority of your mains-powered HiFi gear 2-prong (safety class-II)?
  • Yes
    Votes: 42 41.2%
  • No
    Votes: 60 58.8%
Lambda
budget DACs and Speaker-/HP-Amps from Topping, SMSL, etc are 3-prong,
I wonder if most of the DACs are even connecting the PE internally. Maybe only for a mains transformer shield to keep leakage low.
Suffolkhifinut
I forgot about them. I understand what you mean now. However, it is purely academic. They are not general purpose sockets; you cannot plug in any device that is on sale within the UK. They are for speciality circuits, for instance for lights are switched from a wall switch. I haven’t seen them on any building other than some country house hotel. :)
They aren’t widely in use today and in all honesty had forgotten about them. A few years ago before retirement went to see an Electrical contractor on site the Architect had included them in the electrical specification think it was for a retro effect.
TheBatsEar
Germany
I found out that the power amplifier Yamaha A-S1200 and A-S1000 uses two prongs, but the Yamaha NP-S2000, the network player from that same series, uses three. Does that look random to you as well?
Then there is this guy chilling :cool:
sarumbear
This this wonderful survey has concluded definitively that most of us have both 3 prong and 2 prong electrical gear. I think I could have guessed as much.
If you mean Americans by "us" that is true.
Ingenieur
PA
3 Wire sub, TT and power strip
2 wire integrated and phono amp
Much like isolation xfmrs 'balanced power' is Code regulated. Specifically not permitted for residential use.
The Code does not prohibit things they don't 'like' they do so based on public safety and when allowed it requires additional protections.
The main issues:
-No grounded conductor
-If you have a SL fault only 1/2 the fault I will flow and may not trip the protection. You will likely not know it is faulted.
The faulted line goes to G, ergo, the center tap.
You have 60 V across this short loop.
If a solid bolted fault you have 60 V over 12" of wire (0.4 mOhm) plus line Z., likely huge flash, likely fire.
The other L is 60 V and the under-voltage may damage the load.
That is why special low Z feeder and branch circuits are required, among other things like GFCI, etc.
For those interested
Ingenieur
PA
My Luxman is the same.
Leaving the +/- DC rails floating until the speaker output may reduce noise.
Some amp guru can chime in.
My old Mac had 3 and the sec of the xfmr was center-tapped to frame.
Sal1950
The Chicago Crusher
Central Fl
Tie. NAD M10 and Purifi are Class I. RME ADI-2 FS B and miniDSP 2x4 HD are Class II. I'm currently not running my subs (room space) but when I do set them up, they'll be powered by Sunfire woofer monoblocks (Class 1) or an Adcom 555 (2 prong, maybe not certified).
About the same here, maybe more 2 prongs when I count the 5 Adcom 545 II amps.
Much ado about nothing. ;)
Lambda
If you want to have an balanced power supply get an Type 2 UK building sided transformer
They can be used with an RCD on the output and they get uses in potentially wet environments with potentially damaged cables
like constructions sides.
they are cheap especially second hand but most of them cant be operated continuously at high power.
for example the 1KVA transformer is maybe only 200VA continuous.
theREALdotnet
Ingenieur
PA
Mine has this
2 pin
class 2 double insulated with functional ground
bluefuzz
Back then some older houses still had various round-pin plugs for appliances, and even wiring that had fabric and rubber insulation.
My house (in Denmark) still has fabric insulated wiring for the most part. And no earthed sockets anywhere ... ;-)
KSTR
KSTR
Berlin, Germany
This would then be functional earth (for better EMC).
If they don't connect the chassis (and audio-GND) to PE the internals (power supply) then must be class-II and the device labeled as such. That is, unless a primary shield also doubles up as protective earthing means (quite unlikely).
Which gets us to this...
Not necessarily the case:
Not immediately illegal but a rare case and considered bad practice AFAIK.
It is not clear what's going here. The only thing we know from the labelling is that the device does not rely on PE for safety, that's what class-II is about. It's established by re-inforced insulation of mains-carrying parts and conductors, still protecting in a single-fault scenario.
But, did they just use a 3-prong inlet/fuse/switch combo because it was convenient and the PE is actually not connected to anything? Or did they use it for some form of functional earthing?
Is audio GND and chassis actually floating wrt to mains earth or not? This is the all important question here.
Overall, looking at the number of prongs is not 100% sufficient to tell if audio GND is floating or not but for most gear the correlation holds. 2-prong --> floating audio GND, 3-prong --> earthed audio GND (not necessarily a direct zero Ohms bond. In power amps we often see an "isolator" circuit between audio GND and PE which consists of antiparallel power diodes bridged with capacitor and/or resistor).
sergeauckland
Suffolk UK
Our radio station uses a number of Numark DJ-type CD players as they're cheap enough and include fast cueing and USB inputs. They all are double-insulated, and have the correct symbol, but use the three-pin IEC connector, with the earth pin left floating. I think it bad practice, but seems to be common.
S.
SIY
Alfred, NY
I have a closet full of three pin IEC cords. I'd have to do some major searching to find any two pin. I think I'm typical in this regard. So, yes, it's likely this was done as a convenience and the third pin is vestigial.
