Hello all,
Wish you a happy new year!
I just sold my Yamaha RX-V775 last week along with passive floor standers Yamaha NS-777 for a decent price. The set up was 7 years old. Now I am looking for a processor to connect to my active speakers of 3 LCR Genelec 8340 and 2 surround 8330 for both movies and mch music. I do not have ceiling speakers and so no Atmos. I plan to have ceiling speakers only after a year or two. My set up looks like
this. I would prefer to have the processor hidden in the low board but that's not an important criteria.
My source is only Apple TV for both mch music and movies. Occasionally for good movies, I do blu ray via PS4. Output is 65 inch LED 4K TV KD-65XF9005 and Full HD projector. I also have a 2 ch full digital streaming set up with Raspberry PI and Topping D10s feeding AES into LR Genelec.
The Denon's have measured very well in ASR and 3700 is the most recommended AVR. On the other hand Yamaha fans love the way higher end Aventage series like 3080, A8A, CX-A5200 sounds.
The main testing criteria for pre-processors has been to check for clipping and lower SINAD if they are connected to heavy demanding amps. Is this also true in my case as I will be connecting to Genelec and not any multi channel amplifiers?
Fundamental Question:
Ignoring the measurements of Denon, what is the factor that makes Yamaha sounds better than Denon/Marantz or Anthem for some users. Is it the combo of Room correction/DSP/ Surround AI of Yamaha that gives more details? I plan to switch off the EQ and not use YPAO, as correction is done via the GLM for Genelecs. I use miniDSP DDRC24 to correct my 2 SVS 12 inch subs. So I will be driving more or less in Straight mode with EQ off in the processor.
I am thinking of one of the two options:
Cheap:
Canton Smart Connect 5.1 for around 650 euros
(link). Save money and go for all digital surround set up in few years with Genelec 2*7360 subs and 9301 bass management. Path will be Apple 4K TV -> HD Fury -> Black Magic
HDMI to SDI convertor -> AJA SDI AES embedder or Black Magic SDI AES -> Genelec 9301 -> 8340/8330/subs. At the moment I have only analog subs from SVS. Digital volume control via Apple 4K TV remote.
Cons with the full digital set up: No up mixer or surround AI or virtualiser with digital set up. I am not sure if I need up mixer or virtualised instead of original format.
Expensive - budget 2500 Euros:
Balanced output XLR
Yamaha CX-A5200
Anthem AV60
IOTAVX AVX17
Marantz 7705
Unbalanced output RCA
Marantz 5015 or 6015
Denon 3700
Yamaha 880 or 1080
Multi channel HDMI extractor like
this
Panasonic UB824
I can extend my budget if it is state of the art processor to max of 4000 Euros. Unfortunately monolith HTP-1 is not available in EU. Moreover I can achieve a digital path by least expensive combo of HD Fury with Black magic for less than 1000 Euros. Therefore spending more than 2500 euros seems to be not justifiable.
So in conclusion, I am leaning towards either Canton or CX-A5200 due to the following reasons.
- CX-A5200 costs around 2500 Euros and measured well with Audioholics but not tested in ASR yet. When I go full digital, sell it in EBAY with a expected loss of 50%.
- Anthem AV60 and Marantz 7705 did not measure well here but are cheaper than 5200.
- IOTAVX 17 (link) seems to also ok but costs around 1900 euros and do not know the longevity of this product. Seems to be the version of Tonewinner or Emotive BASX. There is an ASR member who uses the older model and is happy.
- 3700 and 6015 with amps shut down are the cheaper options. Both the units are out of stock and some internet users preferred Yamaha 5200 or other Yamaha AVRs to Denon 3700.
- Yamaha 880 or 1080 does not have the option to shut down amps. I am not sure if the amps are shut down automatically if no cables are connected in the amp section.
- Multi channel HDMI extractor not tested.
- Panasonic UB900 blu ray player was tested here and is recommended. I could ditch Apple 4KTV but I cannot add apps in 824. Moreover no digital volume control. Unfortunately apart from OPPO (discontinued), there is no Blu Ray player with HDMI input ( to connect Apple TV) and with 5.1 channel RCA output.
Question for experts here:
- Is my above considerations reasonable?
- What would you recommend from the above factors?
- Canton is not tested in ASR but has good reviews from many German websites. Looking at the measurements provided from Canton, will this be sufficient for my Genelec set up i.e 1V rms/600 OHM nominal and 3,4V rms maximum with SNR of 101 DB. On the down side, Canton does not offer Dolby Vision. Work around is to use Netflix, Disney in Sony TV and route Audio via ARC to Canton. Also posted are Yamaha measurements.
- Should I go with Canton and save money for digital all output?
Canton measurements
Yamaha CX-A5200 Measurements
Looking forward to your opinion and recommendation!
