A UPS is for power interruptions. Not all models are necessarily immune to being destroyed by a mains surge - kinda back to square one?
This has pretty much been like trying to dig a hole to China. Not by any fault of those commenting. But as I mentioned recently above, I have to work within the parameters I'm given.
The issues are grounding and noise, and how they relate here in Japan.
Like it or not, I have wall outlets which are 2 prong and no ground (and same as the US, for example, are located about lower-shin height from the floor). In my entire apartment, there are only 5 wall outlets which are 2 prong and have a ground screw - 1 in my bedroom for the aircon unit, 1 in the living room for that aircon unit, 1 in the kitchen for the refrigerator, 1 in the bathroom for the washing machine, and 1 in the second bedroom for that aircon unit ( I use this room as a home office/music room). Those outlets are all about 6.5-7 feet off the floor. So even if one were free im my office/music room, it’s not exactly practical to plug in a power strip or surge protector at 7 feet, have it dangling against the wall or located on the total opposite side of the room and then what? Connect every component to extension cords thus creating a huge fire hazard? Call in a construction crew to rebuild the room? Ha ha. I mean, there are practical considerations to keep in mind.
So if I am stuck with 2 prong outlets without ground, which is 100% normal for Japan, and it’s going to be a Mount Everest climb to get my rental agency and building owner to ok switching one wall outlet to a type with ground - it is what it is. Although even if possible to change it, I’m not even sure how that helps anyway. I would plug a power tap or surge protector into the outlet, connect the ground wire to so that device is grounded, but everything I plug into it isn’t grounded by default. The power cable plugs with their own green ground wire also need to connect to something and it can’t be that same outlet ground screw because they would be too far away to do so.
Moving on…
With 2 prong ungrounded outlets, I still need either a power tap or surge protector or UPS, or any other device. With two exceptions - basic power strip/surge protector from here Japan OR a very well built power tap from Oyaide who makes all things power related - those are going to be 2 prong power devices, ungrounded. Anything made from outside Japan is going to be 3p, won’t work in my outlets, will require a 3p to 2p plug adapter, and the adapter ground wire will also not be attached, so not grounded (and any of those power devices when not grounded lose most of their protections because they require grounding to work properly).
The Apple Studio Monitor is 2p with ground wire. I’ve seen it displayed in many shops to test out. The ground wire is never connected in any store. The Mac Mini is 2p with no ground wire. I read that the reason is Apple anticipates the Mac Mini to be connection to the Apple Studio Monitor and thus grounded via its ground wire. So those two devices won’t be grounded. I haven’t personally seen the power cable in Japan for the KEF LSX II LT and Kube 8. I assume they will have a ground wire on the plug but perhaps they don’t. Either way, all four units will be ungrounded.
If this was that much of a concern, I would see every Apple store and electronic store in Japan having the monitor grounded, but they aren’t.
If that’s the way it is, then that’s the way it is. I can’t call and complain to anyone or change the way things are done here. The electrical system here is different, as per the video that a commenter posted over on page 2. I’ve lived here close to 20 years. I’ve never had a blackout, brown out, flickering light, nothing. Not even during the huge 3/11 mega quake and tsunami did I lose power. So it isn't a stretch to say that the electrical system in Japan is ultra stable.
As for noise - as I have mentioned, you can Google Apple Display Monitor along with speakers and noise (or ground loop) and you’ll see dozens of people on Apple forums, Reddit, and the like all complaining about having this monitor and fill-in-the-blank speakers, monitors, and powered speakers and annoying audible noise coming from it.
On one hand. I have read and been told multiple times that it’s pretty much a best practice to pick one wall outlet, plug the power device in (power tap, surge protector, UPS, etc) and then plug all components into that one unit (ensuring the 15/1500 rating isn’t surpassed). This can lower chances of noise and ground loops.
Secondly, I have read that since all these components are not grounded. It’s pretty much impossible to have a ground loop because, nothing is grounded. However, there can still be EMI noise (I don’t recall if that’s the correct name for the noise) due to nothing being grounded.
There is no guarantee this noise will occur, but it’s something to be mindful of just in case. And there is a checklist to follow that can help get rid of this. The last being switching from USB-C to Toslink (and even that has its good and bad points).
So at the end of the day, as I have mentioned before, for something as simple as “Hey, I have a computer, monitor, sub and powered speakers, but can’t find a good surge protector”, it has turned into this bottomless black hole where every suggestion causes a new problem or multiple ones. Try this, but that thats a problem. Then get this to fix that. Then maybe scrap that idea and so this, but it works where you live, but not here. It’s like that.
I am not an expert on power and electricity. Happy to admit that. I’ve had audio component systems before which included a MacBook Pro as controller and all were 3p components with 3p power cables going into 3p power tap and the final power cable had the ground pin removed and plugged into my wall. It worked flawlessly - no noises, hisses, static build up, electrocution, etc. I’ve also had an iMac, with powered speakers and a separate DAC and headphone amp all plugged into a basic power strip with 2p surge protection (and also no noises, fires, problems).
For such a simple set-up, it feels like I’m trying to research building my own components from scratch. I feel like I’m no longer asking anything but just explaining why things are the way they are here. Nobody’s fault but reality.
The only thing that’s going to change every component from being ungrounded is an electrician and new outlets, which isn't going to happen. So now I am on a level playing field with most Japanese here.
The only thing left is noise. I won’t know until I start adding pieces to the puzzle to see if there is noise and if so, what did I last connect that gave noise and how to solve it. And to be clear, by “noise”, I'm not referring to setting up testing equipment and doing a scientific analysis of noise emissions that the human ear isn't physically capable of hearing. I’m talking about noise that you hear, it’s not normal and you know something is wrong.
To repeat myself, I appreciate every single one of you who have read, commented, recommended, and shared here. I don’t consider anything I’ve read as bad advice or useless. Some of it might not apply to me due to different country/power system/plug type/etc, but still it was food for thought.
Unless I am snow-blind now (my mind is already burnt out) I’m pretty sure my options on power devices are either a basic ungrounded power strip without surge protection (all 2p), a much better built ungrounded Oyaide power tap (all 2p) without surge protection, or lastly, a basic surge protector (all 2p). Anything else will be 3p (useless without ground).
And then potential audible noise, which I don’t have yet because I have nothing here to connect. The entire reason for this topic/post was to preemptively source a surge protector before my system arrives.
Sorry for the book.
