- Joined
- May 28, 2020
- Messages
- 1,654
- Likes
- 6,509
Starting to build some simple amplifiers for sale in the US around the Hypex NCxxxMP modules and wanted to make sure my wiring was OK for XLR pin 1: On the XLR connector, Pin 1 will be grounded to the chassis (the Neutriks I use have a tab on the housing to jump pin 1 right to the chassis). For the PCB "Pin 1", it too will be grounded to the chassis, but not at the same exact point used for the XLR Pin 1 grounding.
My question: how close can these two separate grounding spots be? Can I ground the PCB "Pin 1" to one of the screws holding the XLR housing to the chassis even though XLR Pin 1 will be grounded through the XLR housing as well, albeit in a separate spot (like 1-2" away)?
Thanks!
Thanks!
