Suggestions on this Audio setups
without knowing the listening environment is difficult. Focus first on the speakers, listen to them, try others and try to understand the sound you are interested in. Focus on the listening environment, there are speakers more or less suitable for each type of environment and for each application. Then the system options you have listed are all valid, but take a few days to focus on the speakers and environment. Remember that now there are also available, if you need them, electronic and software devices to "tailor" the sound in a more appropriate way to your setup/environment.
Thanks @Mikig for the reply
this is going to be difficult part for me, as I am not in a circle of people with interest in this. Anyway I will jump....
Thanks @JeremyFife for the reply.
I will go ahead with Wiim amp pro + elac dbr62.
Having Wiim amp pro + speaker is better for room correction than wiim ultra + fosi mono + speaker, Is that correct? because of more control for wiim app.
How is elac dbr62 speaker?
The WiiM Amp and the WiiM Ultra have the same room correction, no advantage between them. It's just that the WiiM Amp is cheaper than the Ultra + Fosi combination.
The Elac DBR62 are great speakers. If you wanted to look at alternatives start with the Review Index here - I don't know if Wharfedale Diamond 12.1 are available where you are? I'd be happy with the Elacs though.
I will stick to DBR62 itself, from review index it is good for the price.
