in case you just need someone to decide for you at this point, go with intel for the igpu, 9700 for 65w tdp, 32gb dram for longevity, z390 aorus master for reliability. CM hyper212 evo for quiet. bam, done.
if you have an AMD itch, the 3600 sticks to or below its tdp while offering a bit more single thread oomph, if you want more oomph, the 3700x maxes out your adobe performance at a pretty strict 95w tdp. you will pay more for a good board. i suggest an asus x570-f if you need wifi, x570-e if not. you have to get a discrete gpu; i think a 2060 super is a superb value. the founder's edition or a dual fan from gigabyte or msi are both good bets. same 32gb dram, although the wraith max that comes with the 3700x is comparable to the hyper 212.
on the intel side, if the igpu doesn't meet expectations, same rec, get the 2060 super. at a lower price point, consider the extremely tried and true rx560 or a 1050 ti.
