Suggestions for headphones a little “warmer” than Sony MDR-V6?
Dogen
Durham, NC USA
I’m enjoying my V6 headphones, but for fun I’d like to get an alternate pair that’s a little warmer, without losing detail. The V6’s seem ruthlessly accurate, perhaps lean with a lower treble peak, and I’m looking for something with more bass and midrange body, and less sizzle. Over ear under US$150 would be nice. Driving them with a Topping D3 DAC/amp. Thanks!
solderdude
The Neitherlands
open or closed ?
For closed consider this one (needs other pads) amongst other recommendations you may get.
Dogen
Dogen
Durham, NC USA
I’ve no experience with open (the V6 is closed) but would be...uh...open to open. Isolation is not a primary concern. Thanks for the suggestion!
Dogen
Dogen
Durham, NC USA
Bumping once to see if there are any other recommendations out there. Thanks!
solderdude
The Neitherlands
ATH-M50X
Brainwavz HM5
Beyerdynamic DT770
These all differ somewhat here and there but are all 'side grades'
maverickronin
Midwest, USA
Sennheiser HD 598 or Senn x Massdrop 58X for $150 or less.
If you can get stretch your budget another $50 you could just get the 6XX and be done with it. It's a rebranded HD650 and the absolute best bang for your buck in full size headphones.
Dogen
Dogen
Durham, NC USA
The DT770s - this is the 80 ohms Studio version? I like what I’m reading about these.
maverickronin
Midwest, USA
All the versions sound very similar. The 80 ohm pro version has a tighter headband with a lot more clamp.
SIY
Alfred, NY
1MORE Triple Driver Over Ear. Just a tick under $200. Definitely a warm sound.
RayDunzl
Central Scrutinizer
Riverview FL
These look warmer...
Dogen
Dogen
Durham, NC USA
Aw heck...just ordered a pair of Sennheiser 6xx from Massdrop. It’ll be fun to try something different. Never heard an open-back pair.
bravomail
Closed AKG K550/551/553 - u can get them on harmanaudio refurb pretty cheap. Open - AKG K7xx, Senn 58x, 6xx. Also try Monoprice 8323 with HM5 pads - I have yet to have any headphones so linear (and boring), I had to EQ them to have any fun.
Also, I have Sony 7506, those r sensitive, but too linear.
Audiotechnica M40x is closed, fun, V-shaped.
