Suggestions for an "high sensitivity" 2.1 system build
LF78
Italy
I listened to some high sensitivity / ribbon tweeter systems and fell in love with the sound, so now I would like to build one (to use it for music - not HT). I need some suggestions and/or criticism on the project below: target nominal sensitivity is around 98 dB before DSP and equalization (subwoofer excluded). Thanks in advance!
Source / active crossover / DSP / volume control:
I need at least 5 channels to implement active crossovers in my scenario (2 tweeters, 2 woofers, 1 subwoofer), so my beloved 2x4 HD is not enough.
Left & Right:
2-way sealed enclosure, tweeter crossed at about 2/3 kHz and woofer crossed at about 100 Hz.
Which one do you suggest, or are there any better options?
Subwoofer:
  • Dayton Audio 15" Reference Series (4 Ohm)
I plan to put it in a sealed enclosure crossed at about 100 Hz, which version is it better in your opinion?
Or as usual, are there any better options?
Amplification:
  • Left & Right:
I need 2 stereo amplifiers here, which kind of wiring do you suggest?
  • 1 (less powerful) stereo amplifier connected to the 2 tweeters + 1 (more powerful) stereo amplifier connected to the 2 woofers.
  • 2 identical stereo amplifiers on the left and right channels, each one connected to the tweeter and the woofer
I really need some guidance here, class A/B or class D? Could you help me to shortlist some possible options? I would prefer bare amplifiers and/or amplifier modules without volume control, as it's not needed in my scenario.
Any better options?
