Hello everybody,
as in object I'd love some suggestions on a DAC upgrade I'm planning.
Current system:
Rpi4 (Volumio/MoOde) -> KTB -> Hypex NC500 dual mono --> Beatclub Base DIY Speaker (https://www.lautsprecherbau.de/?serie=901449)
Rpi4 and KTB powered with LPS
I noticed that I do most of my listening in the 40% to 60% volume when regulating with hardware volume control on the Rpi4
These are the reasons why I'm considering to change DAC and replace my Khadas Tone Board.
1) The Hypex modules have balanced input and I'm currently feeding unbalanced line into them. Am I potentially losing something here?
2) I recently bought an android based projector that I'm running with Kodi and it has toslink output, which means that I would need an additional Optical/Coax converter in order to use the SPIDF input in the KTB. On the other hand the capability of the KTB to switch automatically between USB and SPIDF can be quite handy
3) A friend of mine recently bought a AlloBoss2 Streamer/DAC and "subjectively" I really think I could listen to better details in some music tracks we played as b2b on my system
The main products I've been looking at are the Soncoz LA-qxd1, Schiit Modius and SMSL A300mkii.
The question is, do you think buying one of these modules in the 200EUR price range is a worthy upgrade or should I just buy the Optical/Coax converter and stay with the KTB?
Moreover, the Soncoz/SMSL have volume control. When acting on the volume buttons on the unit is it actually the same as changing volume with Hardware volume control from the Rpi4?
Any other suggestion on system improvements/optimization that might be even more relevant than the DAC is obviously more than welcome
Thanks a lot for your help!
Current system:
