After being away from any kind of critical listening—or even the simple enjoyment of music beyond earbuds—for the past couple of years, an upcoming move has rekindled my interest in setting up a simple, small stereo system.
The new living room will have a 4–5 meter wide bookshelf system, with a TV placed somewhere in the middle. I plan to position two smaller bookshelf speakers here as well. I’ll be ditching my current Sonos soundbar, and the new stereo pair will be used for both music and TV. This means I’ll need HDMI support. I also occasionally listen to vinyl, so analog input is a requirement.
Basic requriements
If you have any other suggestions for passive speakers to look for that would fit the pairing with Wiim Amp, or any points what route to take I would be happy as i'm struggling to take stand on where to go from here.
They should be available in EU.
Basic requriements
- Speaker cabinets can't be taller than 32 cm to fit the shelf system.
- HDMI, Spotify Connect, AirPlay (preferably), and analog input for vinyl.
- Budget is flexible, I have the means, but since the speakers will be constrained by being placed inside a shelf, I'm hesitant to invest too heavily.
- Wiim Amp (ticks all the input boxes) + Elac Debut DB53 (or similar small 5” passive bookshelf speakers). I’d prefer going with a DBR62, but it might be too tall given its bigger drivers. Arendal 1961 Bookshelf could also be an option.
- Argon Audio Fenris/Forte 5 (has HDMI but lacks AirPlay and Spotify Connect, so I’d need an additional streamer). These haven’t been measured by any trusted reviewers.
- Wiim Ultra (covers everything except AirPlay, which is fine) + ADAM T5V, or even stepping up to something like the Genelec 8030.
