As mentioned earlier, my speakers have built-in powered subwoofers, so I can't treat those frequencies separately, nor can I move the subwoofers, as they are built into my speakers.
I didn't say that I necessarily want the room equalization unit to stop correcting the response at a certain frequency - I simply said that I would like to be able to tweak the curves myself if I wish to do that. I simply won't know if I would like to do that until I try out the room correction unit. It might not be the treble I would like to adjust, it might be the bass. I can't say until I try it.
However, I would imagine that I would like to aim for the typical downward sloping curve that room correction units create, although I might want to tweak it a little bit here and there.
As mentioned earlier, I also have acoustic products installed (bass traps and first reflection absorbers from Gik Acoustics).
So, I'm considering writing and asking MiniDSP for a recommendation about what unit to choose, but the DDRC-88A that I mentioned earlier seems to fullfill all my criteria, as it has four analogue RCA inputs. It's possible that one of their other units might be just as useful, but I just missed it.
As mentioned earlier, I am considering switching from Naim to Arcam, but if I buy the DDRC-88A, then both amps would suit me equally well, as I would run my three sources through the room correction unit first and then into the amplifier afterwards. The Arcam A39 that I've been considering wouldn't be any better than the Naim if I buy another room correction unit than the DDRC-88A, as the A39 doesn't have a tape-loop, so I would still need to run my three sources through the room correction unit first (unless I've misunderstood something).
Raindance doesn't speak well of MiniDSP, while several of you other guys have suggested that brand. So I don't know what to think of them. Any thoughts?
