For what? Finding whatever is the issue is with CS DACs? Or in general?
Both. I already said that it's for both.
I brought up the dongles' behavior, because it's something I experienced first hand. But I believe there are other potential uses for it.
I think
@kemmler3D made a valid argument that even regular harmonic distortion under 20Hz could have audible consequences, for example. I don't see how that or even ultrasonic induced issues can be just ruled out entirely.
Adding more tests is very onerous when multiplied across every product I test.
I understand. But I didn't ask for more tests, just for slightly changing the existing one, which literally takes a few seconds. Ok, a few minutes if you want to check that the test works as intended.
As for adding new tests in general: I think as long as there are audible issues that slip through, we can't be satisfied. So in that case even asking for
new tests would be perfectly justified and expected. But I'll let others propose and argue for new tests, this one is just about extending the frequency range.
To be clear, there is no case whatsoever for testing products at 5 Hz.
What about the evidence that I provided in relation to the Apple/CS dongles? When such a test points to obvious flaws, how is it not a valid use case?
IMO a proper review should
at the very least spot humanly audible problems that happen under normal circumstances. That's the baseline. And hopefully it would go even beyond that and also cover any potential (inaudible) "safety margin" that a device might have.
If you truly think that audible artifacts (such as those that these dongles produce) are "insignificant", then I'll never bother you with anything like this again. Like, no hard feelings, you have your own standards of "good quality" and I have mine. But that's definitely inconsistent with your previously stated standards, which is why I'm surprised by such a dismissive attitude.
Back on the main topic:
Let me be clear that this suggestion of course applies to anyone who's testing stuff and doing THD+N frequency sweeps. The 20-20kHz range is still the default/standard, but I can't see a rational reason for it being so. If anyone believes that limiting the range that way produces
better test results (as in: more accurate assessment of a device), let me know why please. I suspect that it's just a case of "that how it's usually done", but you never know.
