Motowoodman71
My budget is $250-$300, I have a receiver and an external amp that I want to stream music from spotify & youtube music from my iphone, so airplay2 is needed. From some of my research wiim pro plus seems to be the popular option.
It doesn't support Airplay2 that the OP required.Wiim offers Room Correction, that is a big plus.
If only it were accurate - it lists the Wiim Ultra and Amp Pro as supporting Airplay 2, but they don't. Which others did they get wrong?
All the Wiim streamers have room correction. Only the Ultra and Amp Pro (so far...probably the Amp Ultra too) don't support Airplay 2.It doesn't support Airplay2 that the OP required.
I stand corrected.The Pro Plus does.
Well then save money on this set up and just get the Wiim pro rather than the pro plus, since you'll be using your amp in the main set up mentioned in your opening post.I think I'm set on the wiim pro plus, thanks guys for your suggestions!
Eventually I want to replace my 2.1 bedroom emotiva integrated amp set-up with a wiim amp pro or amp ultra; the interface in the emo is terrible and the volume only works on the remote.
It's true regardless of what operating system you use. Bluetooth supports several audio codecs, ranging from the goddawful SBC codec through to LDAC, aptX HD and LC3plus - all of these codecs are lossy, by design.People say Bluetooth does not support Lossless. That is true if you only use Apple.
A Bluetooth encoder chip accepts an I2S uncompressed PCM signal - it does not care what codec this PCM signal originated as. In other words your source audio file may be FLAC (or MP3, or AAC, or uncompressed, or whatever) but it must arrive at the Bluetooth encoder hardware uncompressed, then the Bluetooth hardware encodes it to LDAC, if configured to use that codec.I use LDAC to stream FLAC ...
That is one way it can work, but not the only way. Encoding and decoding can also be handled in software at the OS level. See for example PipeWire's use of Opus as a vendor codec.A Bluetooth encoder chip accepts an I2S uncompressed PCM signal - it does not care what codec this PCM signal originated as. In other words your source audio file may be FLAC (or MP3, or AAC, or uncompressed, or whatever) but it must arrive at the Bluetooth encoder hardware uncompressed, then the Bluetooth hardware encodes it to LDAC, if configured to use that codec.
A Bluetooth receiver device will then receive this LDAC (not FLAC) Bluetooth stream and decode it back to uncompressed PCM, ready for a DAC to convert to an analogue signal.
Great. Your WiiM Pro-Plus is a solid investment.I'm up & running!
Since you now have a streamer as good as the WiiM Pro-Plus I suggest you bypass AirPlay and instead use optimal casting methods:I want to stream music from spotify & youtube music from my iphone, so airplay2 is needed.
